Exhaust Leak
Old Dec 5, 2000 | 08:43 PM
fatforty's Avatar
fatforty
Exhaust Leak
Old Dec 14, 2000 | 04:38 AM
tundrakat's Avatar
tundrakat
Exhaust Leak
I have discovered a small crack in the drivers side exhaust manifold and can hear the leak when I rev the engine. I have ordered a new manifold & misc parts to repair this. In a EFI engine (351), what effect would this condition have on the overall operation of the engine (other than the back-flow of cold air being hard on the valves).
Old Dec 14, 2000 | 10:23 AM
dre's Avatar
dre
Exhaust Leak
Quick answer, the crack will increase (cast iron with heat does that). You will eventually burn the valves, which by the way, cost alot more to repair than a set of exhaust manifolds.
Old Dec 14, 2000 | 11:37 AM
bjoern's Avatar
bjoern
Exhaust Leak
[font size="1" color="#FF0000"]LAST EDITED ON 14-Dec-00 AT 12:37 PM (EST)[/font][p]In addition, the unmetered air entering the system will tell your O2 sensor that the system is running lean, causing it to change the fuel/air ratio, leading to worse gasmileage.
