TPS Help...
Old Apr 10, 2005 | 06:52 AM
Nobleman15's Avatar
Nobleman15
TPS Help...
Can you please help? I have a 1987 E-150 ford van with a 5.0 EFI Engine & aod trans. Im installing a new TPS, How do I adjust it in the most simple way? Thank you way in advance, mike-
Old Apr 10, 2005 | 09:51 AM
Racerguy's Avatar
Racerguy
There is no adjustment on it unless you drill out the mounting screw holes. Just bolt it on and you should be good to go.
