Body lift
Old Apr 9, 2005 | 08:46 PM
79pos's Avatar
79pos
Body lift
Does the body lift completely replacethe body mount bushing or will I need both the body lift and the other bushings.
Old Apr 9, 2005 | 10:20 PM
Madmike33's Avatar
Madmike33
Installed a body lift on my truck, you add the lift to the original bushings. The lift blocks are usually graphite so if you removed the original bushings your lift blocks would just be hammering themselves into your cab every time you hit a bump. You need to keep the originals to absorb shock... little word if advice, replace the company bushings when you do your lift.. they're usually pretty trashed.
Good luck with the lift.
Madmike33
