Read the procedures in the ....Tech Folder..... before you do it again. Drain the water separator before you pull the filter on the primary fuel filter. Also buy a Fumoto valve.
At least you have a good sense.
SBV45
do you have a part number for the fuel filter Fumoto valve?
Walmart also has a regular oil drain pan with a large funnel shaped top that comes with a cap to close it up when the oil has drained down, and it also has a pour spout to empty it back out into recycling containers.
The one I got is black and is large enough to hold a complete 6.0 oil drain.
There is not a Fumoto valve for the fuel/water separator. You either have to put up with the current setup or make one. I posted a procedure for making a petcock type drain for the fuel/water separator some time back.
