Sponsored by: Auxito
coolant leaking
Old Apr 9, 2005 | 02:12 PM
ifishwalleye's Avatar
ifishwalleye
coolant leaking
I have a 1997 f150 5.4L
there is coolant leaking from a open end hose coming out of firewall on the
passenger side the hose is about 1/2" in dia. and is sticking out past the firewall
about an inch. can anyone tell me what this hose goes to and why it would be leaking coolant out it?
Thanks,
Ifishwalleye
Old Apr 9, 2005 | 04:16 PM
triton_2002's Avatar
triton_2002
Sounds like the heater core. Did the hose come off? You might want to pull up the carpet on the passenger side and check for a leak.
Old Apr 26, 2005 | 06:10 PM
Jedd76's Avatar
Jedd76
Same problem
We had the same problem on My 98 F-250 Light Duty. Ended up The hose goes to The heater core and the Clamp had loosened up and was leaking Anti-Freeze Right on top of the Number for coil Pack and shorted it out. U might want to chaeck that. I tightened it up and The smell and leak went away.
Old Apr 27, 2005 | 05:38 AM
ifishwalleye
Thanks,
It was my heater core, it needed replaced, all taken care of.
thanks for your help,
ifishwalleye
Old Jul 29, 2005 | 12:08 AM
belay's Avatar
belay
Thanks,
Ifishwalleye
I just bought a used 1997 F150 and have noticed the same thing happening. What solution did you come up with? I don't have any of the usual symptoms associated with leaking antifreeze in the cab. Thanks for the help
Old Jul 29, 2005 | 06:41 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome belay, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Aug 5, 2005 | 02:26 AM
hellbenttexan57's Avatar
hellbenttexan57
Ive also got a 1997 150 and it leaked coolant like no other. and not to mention it was blowing like antifreeze vapor through the vents. I took it in and it turned out to be the heater core. you may want to consider getting that checked
