probably can't do it now
Old Apr 17, 2005 | 07:02 PM
mclaughlin31's Avatar
mclaughlin31
Originally Posted by 79driver
I like cornbread's idea, i have thought about doing taht. I will probably end up doing that because it is so hard to find a guage cluster in good shape. The only prblem i see with that is that there is fairly limited space compared to a setup similar to mclaughlin31's. You would just have to position and select your gauges more carefully.
For the tach and speedo, I used the 5" gauges.....You can get 3 3/8"
For the other gauges I used 2 5/8".........You can use the 2 1/16"
That alone would net you some more space.
Just a thought. Trying to give some ideas.
James
Old Apr 18, 2005 | 11:17 AM
iceman320's Avatar
iceman320
mclaughlin, thanks for the help, but if I have to wire in the new sending units i porbably won't change out my gauges because it's too much work to have to drop the gas tanks and then have to try and fin all the other sending units. so I guess i won't be putting in the new gauges after all I could hook them up no problem but dropping the gas tanks is just too much work to have to do. but thanks for the help anyway I think that I will think it over for a while.
Old Apr 18, 2005 | 12:40 PM
mclaughlin31
Iceman,
I have to apologize to you, you do not have to drop the tank, as long as you get the right gauge, you can use your stock fuel sender....I was thinking about the gauges for the motor and not the gas. Sorry, my fault.
james
Old Apr 18, 2005 | 03:44 PM
iceman320's Avatar
iceman320
ok so then the only gauges that I need to use the new senders for is the oil pressure gauge, temp gauge, volt meter gauge, and the tach that I will be adding then right.
Old Apr 18, 2005 | 03:53 PM
mclaughlin31
Right, and the senders come with the gauges. It's never easy doing something diffent
James
Old Apr 19, 2005 | 08:13 AM
KJKozak2's Avatar
KJKozak2
Iceman,
I just made my own custom dash and it was a heck of a lot easier than I thought. I used a flat piece of plexiglass painted Ford blue from the back side. It screws on flat to the face so the guages are on a bit of an angle, but still clearly visible.
You can get 12v LEDs from Radio Shack for a buck or two each. I got two green ones for the turn signals, and a blue one for high beam. I also made new electronic gear shift indicators for the tranny and t-case. The automatic tranny indicator has red, white, green, blue, yellow and yellow LEDs for park, reverse, neutral, drive, low 2 and low 1. T-case also has colored LEDs for each gear. These are all on the dash, too.
For the heater controls, you can remove the original bracket and cut a flat one out of sheet metal. You can screw it on to the dash so the face of the controls is flush with the back of your new dash.
I also got a few wiring wiring connectors from Radio Shack, cut wires from the stock harness and made new ones for the new dash. I spent a few hours figuring out which wire was for what and I wrote it down to save others the pain. If you look at the harness, there are small numbers printed by each wire that coincice with this chart. This is on a 78 F150 4x4, but it should be the same as yours. Hopefully this will help.
Kevin K.
Pin Nimber - Wire Color - Description
1 RED/YELLOW BRAKE WARNING LIGHT (-)
2 --NOT USED-- --
3 --NOT USED-- --
4 PURPLE/WHITE BRAKE WARNING LIGHT (+)
5 PINK SEAT BELT WARNING LIGHT
6 GREEN/BLACK HIGH BEAM INDICATOR
7 WHITE/GREEN RIGHT TURN SIGNAL INDICATOR
8 RED/WHITE WATER TEMP GUAGE
9 BLACK DASH LIGHTS (-)
10 LT. BLUE/RED DASH LIGHTS (+)
11 YELLOW/BLACK AMMETER (C)
12 RED/ORANGE AMMETER (D)
13 GREEN/WHITE LEFT TURN SIGNAL INDICATOR
14 BLACK FUEL SENDING UNIT (REAR)
BLACK/GREEN FUEL SENDING UNIT (MID)
15 ORANGE FUEL GUAGE (EMPTY)
16 --NOT USED-- --
17 WHITE/RED OIL PRESSURE GUAGE
18 --NOT USED-- --
Old Apr 19, 2005 | 10:32 AM
iceman320's Avatar
iceman320
kjkozak2, do you have a pic of your dash panel installed in the truck that I could see just so I could get an Idea of how I want to do my panel. thanks.
Old Apr 19, 2005 | 10:49 AM
77460ford's Avatar
77460ford
ok guys I have been looking at my dash today and I have noticed that I am going to run into problems with making my custom dash panel first of all how am I going to angle the gauges upward, and second what am i going to do to angle the panel where the heat controls and the radio are. because I don't have a welder and I don't know how to weld aluminum so for right now I think i'm screwed. and am thinking about just giving up on this whole idea. if anybody else has any ideas please feel free to post them. thanks.
Hi Iceman, I looked at several trucks that had custom panels put in but only a few took the time to mount them on an angle. I took an old dash pod and gutted it, mounted a speedo (not the bathing suit) on one side and a fuel gauge and LED's for blinkers and high beam on the other. The monster tach sits on the column and blocks the view of the center so I blanked it off. I'm just about done but I could send a pic(s) if you are interested. This all sits behind the normal cover. Every time I get frustrated I look at some of the fine work posted here and get back to work on it. Good luck.
John.
Old Apr 19, 2005 | 11:12 AM
KJKozak2's Avatar
KJKozak2
I have pics at home. I can send some tomorrow.
I'm thinking I'm gonna redo the whole thing and tip it back cuz I can't get the speedo cable to hook up. I also ran into problems with the heater controls hitting the ducts. Even though it looks nice IMO, it's a hack job. I rushed through it to see if it would work and I plan to redo it right.
I used the stock fuel guage and adapted it into an old tach case so it looks better. I also used the original speedo mechanism in a home made case. I didn't have a numbered background plate so I used a Miller Lite coaster from the local bar for the time being.
Like I said - hack job.
K.
Old Apr 20, 2005 | 08:09 AM
KJKozak2's Avatar
KJKozak2
Ok. check out my 'justpix' gallery. I put a pic of the dash in there this morning.
K.
Old Apr 20, 2005 | 10:42 AM
iceman320's Avatar
iceman320
ok one more question, if I don't have to change the sending unit for the fuel gauge why do i have to put in new one's for the rest of the gauges?
Old Apr 20, 2005 | 11:30 AM
mclaughlin31
The fuel gauge is measuring a level, the gauge is meant for a ford or chevy ect.. depending on OHMs. The rest of the gauges come with sending units. My question for you is, why spend $400 on gauges and not use the new sending units that come with the gauges........The work involved in fabbing up a gauge panel is a heck alot more work than what is involved in changing out a few senders. You sound like you already have your mind made up. If you don't want to change them out, best of luck.
James
Old Apr 21, 2005 | 03:46 PM
  #28
iceman320's Avatar
iceman320
ok guys, I found two of the sending units on my engine yesterday the one for the temp in on the front of the engine below the water neck, and the one for the oil pressure in on the back of the intake manifold behind the carb, but where is the sending unit for the voltmeter? I know that it's probably on the silinoid that's by the battery but which sending unit is it because I think that there's two sending units on the silinoid.
smisek
Bronco II
Dec 2, 2014 10:25 PM
smisek
1983 - 2012 Ranger & B-Series
Sep 26, 2014 12:35 PM
KG Excursion
Jul 14, 2014 10:09 AM
Mazz
May 22, 2014 07:56 AM
Wicked Endings
Jun 22, 2013 10:21 PM
