oil leak
Old Apr 8, 2005 | 05:02 PM
Rob Cuenin's Avatar
Rob Cuenin
oil leak
why is oil being pushed up out of the dipstick tube with the dipstick in? 351m
Old Apr 8, 2005 | 05:43 PM
ranger429's Avatar
ranger429
The only thing I could think of would be a bad ring causing compression in the crankshaft. Might want to do a compression test on the cylinders..
Old Apr 8, 2005 | 06:00 PM
Rob Cuenin's Avatar
Rob Cuenin
ever here if removing the smog pump will cause this oil leak
Old Apr 8, 2005 | 08:51 PM
ranger429's Avatar
ranger429
Not that I am aware of.
Old Apr 8, 2005 | 09:10 PM
Torque1st's Avatar
Torque1st
Posting Legend
Pad PCV valve or system.
Old Apr 9, 2005 | 04:55 AM
Rob Cuenin's Avatar
Rob Cuenin
i took the #1 plug out and turned the motor over and theres a light spray of water coming out as the motor spins over. did a compression test and that cylinder has none not too good ?bad headgasket and broken ring in that cylinder?
Old Apr 9, 2005 | 07:11 AM
ranger429's Avatar
ranger429
If you have water coming out it is probably a bad head gasket, it could also be a crack in the cylinder wall. Did you check the rest of the cylinders? Do you have water/A/F in the oil?
Old Apr 9, 2005 | 12:28 PM
Mil1ion's Avatar
Mil1ion
The reason it comes out the dipstick tube is because the regular place for the crankcase pressure to evacuated is plugged.
PCV Valve = Positve Crankcase VENTILATION valve.
The pressure made by the pistons going up and down, has to go somewhere.
Old Apr 9, 2005 | 01:22 PM
Rob Cuenin's Avatar
Rob Cuenin
im buying a rebuilt longblock and thats that does anyone recomend a good place?
Old Apr 9, 2005 | 04:49 PM
ranger429's Avatar
ranger429
Old Apr 9, 2005 | 06:18 PM
460me's Avatar
460me
I have the same problem,replaced pvc and cap on other vavle cover.Stills blows.
Old Apr 10, 2005 | 05:27 AM
Rob Cuenin's Avatar
Rob Cuenin
no water in oil and theres compression in all the other cyclinders and new pcv valve low oil pressure 10 lbs warmed up in gear and making odd noises
Old Apr 10, 2005 | 06:05 AM
towtruck's Avatar
towtruck
Rob, you may have two problems.
One, the dead cylinder, that will make it sound odd. This could be from a number of things. Bad piston, bad rings, blown head gasket, warped head, a crack somewhere, ECT... I don’t think this alone will cause oil to blow from the dipstick.
Two, Oil from the dipstick. This is most likely from all of the cylinders being worn to the point that they are causing severe blow by. This will over run the pvc system and push air from the dipstick tube. Very worn cylinders will cause the pistons to slap, odd sound also. The last engine I had with this problem had the cylinders nearly worn .030.
If you do go with a rebuilt long block I would go with a 400 to replace the 351m.
Old Apr 12, 2005 | 03:44 PM
460me's Avatar
460me
Not to steal he's post,but:
I'll do a compression test and reply again.No smoke out the pipe and no hard starting hot or cold.It has a rear main oil leak,so we are going to pull the motor and rering and rebearing it.Drove it 240mi back home with a 24' 5th wheel,what a mess.Only a quart and a half................
Old Apr 13, 2005 | 01:55 PM
460me's Avatar
460me
compression test results
front
D P
1-120 1-125
2-120 2-120
3-105 3-105-----this one the spark plug was ashed upped
4-100 4-100
all onther plugs looked great
would and bad EGR make that plug look like that?
