fuel pressure?
Old Apr 8, 2005 | 01:17 PM
fish-albuq's Avatar
fish-albuq
fuel pressure?
i have a carter electric fuel pump feeding my dual holley 450's and on hard acceleration it back fires and acts like its not getting fuel. my gauge shows 5.5 . im thinking that im not getting enough fuel. the truck runs great except when you really get on it. do you guys agree that the fuel pump may be the problem? thanks
Old Apr 8, 2005 | 02:26 PM
Randy Jack's Avatar
Randy Jack
Fish -
No, I think you've got plenty of fuel pressure. My guess would be timing. Are you running a vacuum advance or mechanical. I'd check the timing and the vacuum advance.
Old Apr 8, 2005 | 04:19 PM
fish-albuq's Avatar
fish-albuq
randy, i have set the timing and its good to go. not using vacum advance. even changed the jets in the carb. not sure whats going on but definately want to fix it, going slow sucks.
Old Apr 8, 2005 | 04:40 PM
Randy Jack's Avatar
Randy Jack
Fish -
Might you have a vacuum leak in the intake manifold? When mine backfired a lot (under acceleraation) that's what it was.
Sorry, not more help here...
Old Apr 8, 2005 | 05:59 PM
Christopher2's Avatar
Christopher2
Veteran: Navy
I wouldn't assume you are running lean. I had a vehicle with the same symptoms and it was running rich. Is this a new setup? Has this setup ever worked correctly on your vehicle?
Old Apr 8, 2005 | 10:17 PM
fish-albuq's Avatar
fish-albuq
actually it is a new setup. i bought the kit from summit, 2-holleys and a tunnel ram. sure runs good, except when you really get on it.
Old Apr 8, 2005 | 10:57 PM
Christopher2
Veteran: Navy
Post
Can you pin point it to a RPM or throttle position? I am not sure what else you have done to the motor but I would reccomend that you take the truck down and have it dyno tuned. They can tell you which cylinders are missing at what RPM under load and if you are running rich or lean. You should be able to take it to a modern local garage and put a meter in the tale pipe and tell you if you are running rich or lean. In the long run I bet it would be cheaper than guessing and throwing money a problem you don't fully understand. Running the test on a Dyno will help you understand the problem.
Old Apr 9, 2005 | 05:57 PM
fish-albuq's Avatar
fish-albuq
yeah, ive been kind of contemplating that. thanks for the advice fellas
