plastic headlight lenses
Old Jan 1, 2001 | 03:10 AM
daford's Avatar
daford
Someone on this site has had to of had this problem.
I have a 88 full size Bronco and it has the sealed plastic headlight lenses. Now the problem is when I'm driving at night I can't even tell that there on because the lens is fogged up and moist is there anyway to fix this?
Thank You
daford
Old Jan 1, 2001 | 07:18 AM
PAUL_2's Avatar
PAUL_2
Sometimes especially if you live in a humid climate or its been raining or snowing a lot moisture gets inside the lens . You can remove the bulb & what I have done in the past is switch the hose around on a shop vac so that it blows semi warm air , it works better if you have a heated garage . It takes a few mins & that usually dries out the lens .
Old Jan 1, 2001 | 08:02 AM
DannyP's Avatar
DannyP
In my truck I had the problem of the reflective coating on one lens peeled off and it wouldn't put out enuff light to read a book.
DannyP
89 F-150 4x4 former EFI I-6 now carbed 351W, Edelbrock heads,cam,intake,carb.
MSD 6A, ZF, Sterling 10.25 with 3.55L's.
Old Jan 1, 2001 | 11:10 AM
Pastmaster's Avatar
Pastmaster
When I was down by the gulf of mexico, I noticed alot of vehicles in general that had "yellowed" headlights and front turnsignals. I alway's thought, that it was very humid when the light was changed, thus causing moisture to stay inside, causing the yellowness. Could this be true?
Old Jan 1, 2001 | 11:50 AM
PAUL_2's Avatar
PAUL_2
What Ive found is the rubber O ring on some of the bulbs dries out let moisture in around it . Seems to me its the GE bulbs , I replaced mine with either Phillips or Sylvannia bulbs & havent had a problem .
Old Jan 1, 2001 | 12:30 PM
fatforty's Avatar
fatforty
rabbithutch
Sep 27, 2005 10:32 AM
slave2dafords
Dec 10, 2002 11:14 AM
slave2dafords
Nov 30, 2002 11:26 PM
daford
1978 - 1996 Big Bronco
Aug 18, 2002 02:59 PM
daford
Apr 2, 2002 06:33 PM
