Once the tire is off ibelieve i see another 8 or so Nuts to be removed around where the locking hub is, Is this correct to remove them first to replace the rotors??
i had a big problem getting the adjusting nut off, if you run into that problem you might have to rent an impact wrench. One of the electric impact wrenchs will work. But most people havnt had this problem, but i know im not the only one.
Its a 2000 F350 dually crewcab with the locking hubs on the front and also the electronic shift **** in truck for 2w high, 4wd and 4w low.I took off the 8 tire nuts and then see theres another 8 nuts holding hub to rotor.
Reason: added
The rotor is held tight to the hub by the lugnuts holding the wheel on and retained by the caliper when the wheel is off. This is how most front-wheel drive cars have been for years.
