Bfg 285/65/r18
Old Apr 7, 2005 | 12:22 PM
mw1063's Avatar
mw1063
Bfg 285/65/r18
Is anyone running BFG All Terrain K/O 285/6/R18's on their stock rims? If so do you have pictures?
Old Apr 7, 2005 | 02:44 PM
YOMAN's Avatar
YOMAN
YEs there are VERY few has it on their truck but its national back order for 18" rims its approx 33x11.5 / 18
YOMAN
Old Apr 12, 2005 | 07:52 AM
mw1063's Avatar
mw1063
Anyone else?
Old Apr 12, 2005 | 08:48 AM
MX2004's Avatar
MX2004
mw1063, the closest I could ever find someone with tires like that is industrialjunk. He's running on 315/70/17 with stock rims.
https://www.ford-trucks.com/user_gal...&albumid=13316
From what I've read, those tire's will fit just fine on stock rims, no rubbage
Old Apr 13, 2005 | 11:19 AM
zhigaag's Avatar
zhigaag
Try searching google. I was able to find the pics you are looking for some time ago. The truck I found had the tires on factory rims and a leveling kit. Unfortunately I dont have the info any more. I will keep looking though.
Old Apr 13, 2005 | 01:47 PM
jaytee04's Avatar
jaytee04
Post
Yoman, You are wrong. The 285 is approx. a 32.3 inch tire not a 33.....but very close.
Old Apr 13, 2005 | 03:49 PM
zhigaag's Avatar
zhigaag
Actually they are 32.8 which is close enough for me to call them 33.
Old Apr 13, 2005 | 04:06 PM
YOMAN's Avatar
YOMAN
geez i m sorry that I M WRONG...its only .2 different..geez...hehe!
YOMAN!
Old Apr 13, 2005 | 06:28 PM
jaytee04's Avatar
jaytee04
zhigaag, you are wrong. i have the same tire we are talking about and i JUST MEASURED RIGHT THEN. They are not 32.8... they are 32.3
Old Apr 13, 2005 | 08:50 PM
YOMAN's Avatar
YOMAN
jaytee04,
huh? you serious? BFG website said 32.8" grrr....wtf?
what psi do you have on your tires? i guess you got 285/65/18 BFG ATKO ?? if you do, how the heck did you find ones ??
YOMAN!
Old Apr 14, 2005 | 01:01 PM
zhigaag's Avatar
zhigaag
Jaytee04 - There must be some conspiracy. BFG is lying to us all as I took the specs from their documentation. Is it possible that your tires are worn or under inflated? Either way thanks for the valuable info.
Old Apr 14, 2005 | 01:18 PM
igotoneforya's Avatar
igotoneforya
285mm in width = 11.22 inches
285 X .65 = 185.25mm sidewall height = 7.29 inches
2 sidewalls (7.29 X 2) = 14.58 + 18 inch rim = 32.58 inch tire.
The manufacturer has a 4-8% error rating depending on brand. Some 285/65/18 could be 33 inches and some could be 32 or anywhere in between. There are some tires that measure 36.2 inches but are branded 37s. It is all legit. Air pressure makes a big difference in height as well as in MPG. That same tire you measured on your truck would measure taller on my Jeep due to weight sitting on the tire. The .5 inch of discrepancy is less than 2% error. Tough to be that accurate with a mounted tire and a tape measure.
Old Apr 14, 2005 | 04:09 PM
jaytee04's Avatar
jaytee04
hey you guys! i know yall thank i am annoying but i promise my tires were 32.3 inches tall. I ordered these tires thinking they were going to be approx 33 but they weren't... but they were close enough like yall said. After i got them mounted and put on i measured them. But i rolled a brand new 33" in. up next to mine and my tire was "domed" higher in the middle. So then i measured up and level to the very tip top of the tire yesterday, and it was 32.8. So the deal is it measures up to about a 32.3 from the ground to the very top of the sidewall...but when you measure up above the sidewall right where the tire domes at the top, it measures to a 32.8. So..... it is close enough, right? Sorry it was my mistake.
Old Apr 14, 2005 | 04:16 PM
jaytee04's Avatar
jaytee04
Either way you guys, if i could do it over again, i would get the 33" in. tire because they just look sooooo much wider than my tire. I know it is only a inch but that inch does make it look alot wider. But these tires are very nice and the good thing is they dont put hardly any strain on my engine when i floor it.... but i do have the hypertech power programmer so that also helps out.
Old Apr 14, 2005 | 07:58 PM
k80kid's Avatar
k80kid
I have those tires on my truck and like them very much, there are pics in my gallary..
