4.2 problems
Old Apr 6, 2005 | 08:37 PM
wadup's Avatar
wadup
4.2 problems
Hi there. Hope this post is in the right spot. Anyway.....
I have a buddy with the 4.2ltr in a 98 e-250 van. When he is on the highway it seems to stumble and buck bad. It idles fine and at WOT it goes fine also. We are trying to track down the issue and with a little reading online I think it is the mass air flow sensor. Has anyone else had the same problem? Was it the MAF sensor? Where is it located on this van. Man it is tight in there.
Anything else I should be looking at? That sensor isnt cheap so i dont want to drop coin on it if it is not it.
Thanks
Old Apr 6, 2005 | 09:21 PM
rmanTX's Avatar
rmanTX
you can try spraying electrical contact cleaner on it, to clean it up. Try the IAT also.
but i fear that problems with either of those sensors would be present during idle as well.
hmph.
Old Apr 7, 2005 | 08:17 AM
wadup's Avatar
wadup
Thanks for the reply.
Is there anymore info on what it could be?
Old Apr 7, 2005 | 11:54 AM
BrianA's Avatar
BrianA
No codes I'm guessing or you would have mentioned such.
I'd expect a bad MAF to cause some kind of code.
The MAF is inside the plastic piece located just after the air filter. It has a wiring harness (5 wires I think) that plugs into it.
How many miles on the engine?
Any previous service issues or recent service work?
Old Apr 7, 2005 | 09:32 PM
wadup's Avatar
wadup
Ya no codes. I was reading that there was a service bulletin from ford saying that the MAF sensor goes bad in this engine and it may not trigger a check engine light.
120,000 on the engine and nothing changed as far as tune up. Going to do all that in time.
noddinoff
3.8 & 4.2L V6
Nov 2, 2016 07:41 PM
merritt691
1997 - 2003 F150
Sep 27, 2012 11:03 PM
Sopranos
Mar 3, 2012 07:44 AM
joelmilot
Crossovers
Jan 6, 2011 08:34 PM
black00stang
3.8 & 4.2L V6
Oct 9, 2007 08:46 AM
