Hot alternator..
Old Apr 9, 2005 | 04:52 PM
  #31
me1mckee's Avatar
me1mckee
Checked mine at work Friday. Truck sat all day (9 hours). Before start it was 78 degrees outside, alternator temp was 82 degrees, same as other underhood temps. Started engine--30 sec., 95 degrees/ 1 min., 105 degrees/ 90 sec., 120 degrees and stayed at 120-125 for another minutes, then cooled to 115-120 after glow plugs were off, I guess the batteries were up enough to draw less amps. I will try again Monday to make sure that these numbers are consistent. I checked at the exhaust inlet to the turbo at the end of this time and the inlet pipe was 195 degrees, idled the whole time. I will try it at 1200 RPM's also and see if that makes a difference with the alternator. Also, the alternator was very warm to the touch, but not so hot that I couldn't hold my touch it.
Old Apr 9, 2005 | 04:55 PM
  #32
me1mckee's Avatar
me1mckee
Lightbulb
All temps are with a digital laser temp tester pointed into the inside of the alternator, not the casing or fins or edges. As far as load on the electrical system, I have a radar detector and CB radio that stay on all of the time and all of the lights were off. I put all of the windows down while the glow plugs were warming up and did not have the A/C on at all.
Old Apr 9, 2005 | 05:27 PM
  #33
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Do most if not all of you have only one...I have one....
Old Apr 9, 2005 | 05:48 PM
  #34
me1mckee's Avatar
me1mckee
I only have one, sorry I didn't add that detail. No programmers or tuners or any other mods. Just the CB and radar detector on all the time.
Old Apr 9, 2005 | 08:51 PM
  #35
myfordf350's Avatar
myfordf350
I have some helpfull infomation for all on this thread in regards to the Hot Alternator issue.
I told a friend of mine to let me look at his 2001 Chevy Silverado's Alternator before he started it.
It was cold, Then after he started it, It Got HOT !!
Could this be the way Alternators are on all vehicles.
Hope this helps
Old Apr 10, 2005 | 06:59 AM
  #36
IB Tim's Avatar
IB Tim
IMO it is the designing and “duty cycle” of the alternator that is causing the heat...I will still bring home a thermal heat gun on Monday to test
Remember myfordf350 when we have a situation which we are systematically looking at and figuring out…we ALL want to do it through good investigating and testing, we NEVER want to immediately say are trucks are junk and run off to the dealerships.
The level of intelligence, technical know-how is phenomenal in FTE...So all the smart guys start to diagnosis these problems calmly...they all gather data compare notes and see if further discussion is needed ....with our respective dealers...so yes add input but STAY CALM>
Case in point; many times a new person will come in and ask a question, at times the answers are short, “get it in to the dealer” then other are discussions about certain parts a sensor or …this is how we work here in FTE.
Old Apr 10, 2005 | 07:15 AM
  #37
150ford's Avatar
150ford
Ok I just started my diesel tractor the other morning. Got off put my hands on the alternator. Very hot couldnt keep my hands on there. The alternator is just doing its job. Normal occurence. Checked again later it was cooler.
Old Apr 10, 2005 | 07:35 AM
  #38
Bob Ayers's Avatar
Bob Ayers
Yes, it's normal for an alternator to get hot. If you think about it, 12V and 100 AMPS is 1200 WATTs of power!! On some Mercedes, they have a hose
running from the back of the alternator for pulling cool air (outside the engine compartment) to cool the alternator.
Old Apr 10, 2005 | 07:43 AM
  #39
IB Tim's Avatar
IB Tim
Thanks Bob and 150ford …these posts are great for all of us......especially members like me who REALLY don't do the electrical thing
You all have added a calming affect to my original problem and concern.
Old Apr 13, 2005 | 04:04 PM
  #40
moebdick's Avatar
moebdick
Hey Tim, I stumbled onto this alternator graph (click here) and thought you might be interested. It doesn't really answer why yours gets hot so quick, but it is fairly obvious that the things are able to handle a lot of heat.
Also note that Ford's "130 amp" output rating is a bit on the optimistic side for most real-world performance situations.
BTW, the graph is from an alternator performance curves doc on the the Ford Body Builder site.
viper29
Jan 14, 2014 11:12 AM
Natcox012
13
Dec 8, 2013 10:40 PM
npccpartsman
Oct 27, 2013 11:58 AM
VRC9170
Aug 2, 2011 06:04 AM
tasdad
Apr 28, 2005 08:53 AM
