57-60 corners
Old Apr 6, 2005 | 04:36 PM
scrape's Avatar
scrape
57-60 corners
hey guys, does anyone know of a company producing or selling inner and outer rear cab corners for the 57 - 60?, also inside the 48 - 52 cabs where the front door pillar meets the floor, there is a brace panel that incorporates the hole for a cab mount bolt, does anyone make these? replicating it with flat is easy but i can't figure how to press in the raised section that gives it all it's strength.
cya....gary
Old Apr 6, 2005 | 09:59 PM
My58Ford's Avatar
My58Ford
classicfabrication makes the inners.
Old Apr 7, 2005 | 12:35 AM
77Chief's Avatar
77Chief
Check out LMCtruck.com part #s 49-9022, 49-9023, 49-8856, and 49-8857.
Old Apr 7, 2005 | 05:21 AM
Walston's Avatar
Walston
classic fabrication makes the cab mount supports anf inner rear corners, they also make replacement floors. They have a website that gives their phone number, you need to call them you can't order them online. Front floor replacements for both sides, both front cab supports and the rear inner cab corners cost me about $400.
Old Apr 7, 2005 | 11:28 PM
My58Ford's Avatar
My58Ford
Hey Walston!
That's exactly what I ordered from them, but...
I was a little dissapointed because I thought I was getting exact replica floorpans & cab mounts, but they are different than the originals, I'm sure you noticed.
Now I'm thinking of just splicing in certain areas to try to retain as much of the original sheetmetal as possible, but I don't know if it will work out or not because of the huge difference in the panels & mounts.
I guess I'll see when I get to that point.
Old Apr 8, 2005 | 05:21 AM
Walston's Avatar
Walston
The cab mounts and inner corners matched the original perfectly. The gruves in floor pans were a little different, but they fit well.
Old Apr 8, 2005 | 07:16 AM
My58Ford's Avatar
My58Ford
Really?
Well I have'nt got that far yet but the cab mounts definately look different to me, the originals sort of angle down to where they meet the step where the one's from classic fab look straight.
Guess I'll find out soon enough!
knucklecars
Oct 2, 2016 11:09 AM
johnfin1
Aug 10, 2016 01:28 PM
bbender85
2004 - 2008 F150
Jul 25, 2016 11:06 PM
cbutcher
Jul 13, 2011 10:59 PM
bigjim350
Dec 11, 2008 09:24 AM
