How much suspension height?
Old Apr 6, 2005 | 04:31 PM
79beater's Avatar
79beater
I have an 88 F-250 4x4 (TTB)with the 7.3L. I have noticed that the front end only has about 3/4 inch gap before it is sitting on the bump stops.
Can any one tell me if this is correct?
Thanks,
Adam
Old Apr 6, 2005 | 04:53 PM
luvthesnow's Avatar
luvthesnow
Seems low. I am in the process of putting in add a leafs to the front of my 94 (351). My stops are about an inch away with too much negative camber.
Brian
Old Apr 6, 2005 | 06:27 PM
tex94F250's Avatar
tex94F250
Mine measure 1 3/4" off the bumper withe the two leaf set up and a 460 in an F250. The diesel weighs a fair amount more than even a 460 so you may be in the ballpark.
Old Apr 6, 2005 | 06:51 PM
crazandy's Avatar
crazandy
That's about what mine is like. ~2" and a 460 F250 S/C
Old Apr 7, 2005 | 11:38 AM
79beater's Avatar
79beater
Yhanks for the replys.
It just seems like it is always bottoming
Old Apr 7, 2005 | 05:50 PM
tex94F250's Avatar
tex94F250
Have the springs re-arched. Don't know where you are, should cost around $100.00 just to re-arch, you pull & re-install. You'll need new bushings. You'll also need patience and a big hammer to install without a press.
