tranny identity help in my 82 f150 stepside
hi im working on my tranny now my truck is an 82 stepside and the transfercase and tranny are no longer working well i want to get another but dont know what i have so hear it goes number on the side starts with d9 so 79 i know its a 3 speed with over drive but reverse is over to the left and up but you have to push down on the shifter .......the transfer case has a round metal tag and says new process and next ?????????????my truck has a cleveland in it can i go ahead and buy an 86 truck and use its transfer case and tranny
numbers on tranny are rug PB29 eltrpa 0579
rfd9-1006-ab
c-2604194
transfer case numbers are
new process gear
model 208f
ratio 261
serial number is 1110-81
rfd9-1006-ab
c-2604194
new process gear
model 208f
ratio 261
i looked it dont look like those ones it looks kinda like a top loader but the top loader spot as a plate bolted to it and the shifter is on the side od the tranny it looks like a small starter or something and the tranfer case has a big metal thing that mounts to both sides of the tranny its got like a funny center section between the tranny and transfer case seems this is where the shifting may be done for the transfer case
Forget about the transfer case for now. Some of the transmission shown on that page are 2wd, some are 4wd. Doesn't change the basic ID of the trans itself.
If you have a 4 speed overdrive, it is probably one of the first three. Note that only the SMOD is show. Read the descriptions for the next two - the SROD and TOD. If you have an 85, it is probably the TOD.
Edit: Sorry, I think the trans shown is the SROD, not the SMOD. Not 100% sure.
The one in the picture is the SROD. Note the tube extending back from the side of the trans. At the back end of that tube, there is a turret and the shifter mounts there.
The top shifted units have the shifter on the top of the trans--the tin plate on top is replaced by the shifter mount set up.
The side shifted units have external linkage and shift arms out the side--you can see the holes in the castings in the picture. The side shifted units have 3 shifter arms out the side.
The center section between the trans and the TC is the TC adaptor.
The '86 truck, what trans does that have in it.
A Cleveland motor? Did you install that?
AGAIN OVERDRIVE OR 4TH SAME AND REVERSE IS OVER TO THE LEFT AND UP
IT WAS INSTALLED BEFORE I BAUGHT IT ILL GO OVER TO NEABORS AND LOOK AT THE 86 TRUCK AND SEE WAT IT LOOKS LIKE FOR SURE REMEMBER MY TRANNY THE REVERSE IS TO THE LEFT AND UP BUT YOU HAVE TO PUSH DOWN ON SHIFTER TO GET THERE
GRRRRRR THE 86 TRUCK IS TOP SHIFTED NO BIG STEEL THAT SHIFTS THE TRANSFER CASE EITHER
ok so i think its the second tranny listed from only 80 to 83 now how hard are these to find
sorry bout the caps the tranny is wineing real bad in all gears except third. i belive bearings as well when its in neutral and i let the clutch oout it really wines bad like the bearings are coming apart..
the tc wont go int 4 wheel drive at all ..and before that it would not stay in 4 high it would jump out and if it did stay in about evry half mile or so it would make a huge clunk as if the chain or something was sliping and the truck would feal like it was lifting off the ground
General
17
11-11-2007 01:16 PM
serving_time
10-21-2005 09:58 AM
ssmcclure
02-08-2005 12:33 PM
