96 Explorer O2 sensor problem
Old Apr 5, 2005 | 07:22 PM
KawiG5's Avatar
KawiG5
Unhappy 96 Explorer O2 sensor problem
The check engine light came on today and the first thing to come to mind was O2 sensor. I took it to Autozone to have the codes pulled and sure enough I was right. Code P0420 came up indicating bad O2 sensor bank 1. Now my problem is which of the front 2 sensors is it? Code P0421 (which did not show up in the scan) is also for a bad sensor on bank 1 which indicates to me that each O2 sensor has it's own code. Is P0420 for the driver side or passenger side O2 sensor? Any help would be greatly appreciated.
Old Apr 5, 2005 | 07:44 PM
bulldog3531's Avatar
bulldog3531
bank one is the driver side i just did mine on a 98 sport the electrical connector was a bit tight to get to. good luck
Old Apr 5, 2005 | 08:53 PM
KawiG5's Avatar
KawiG5
My Explorer XLT has 4 O2 sensors (2 before the cat and 2 after it). Bank 1 is for both pre-cat sensors and each has their own trouble code when bad. The same goes for the 2 after the cat and those are bank 2. The code I got was P0420 which is for one individual sensor on bank 1. Just which one it is I have no clue.
