Leaking fuel pump
Old Apr 5, 2005 | 02:43 PM
99F150's Avatar
99F150
Question Leaking fuel pump
My 1965 F100 with the 300 cube six has the fuel pump with the filter on top of it. The pump is leaking gas when I shut the truck off. Can repair part be bought for that pump? NApa sells the pump but is $50.00 and is a order item. I did a search for fuel pump repair and the search engine gave me 300 results with no mention of fuel pumps, PArking brake cables and power steering. Whats up with that? Did it search only the word "repair"?
Thanks for your help.
Dan
Old Apr 6, 2005 | 06:37 AM
barry's Avatar
barry
Have you tried anywhere else? It seems high in price. It's probably a good quality one if it's NAPA. I hate to recommend this, but have you tried AutoZone or Advanced? You can get kits to rebuild, but they're special order also. It fits 65-72 and maybe a little later. Ford part number for the pump was C3AZ 9350-Y. Have NAPA or any other place crtoss the ford number over to ensure you getting the correct pump.
Barry
Old Apr 6, 2005 | 12:47 PM
barry's Avatar
barry
I tried the locator and there a bunch of NOS Ford ones out there. If you want genuine, let me know and I'll post who has them. There's one place in Texas who has 20.
Barry
Old Apr 6, 2005 | 12:52 PM
99F150's Avatar
99F150
Thanks, I am not to concerned about that, as this is a un restored daily worker yet. I am going to take the pump apart tonight and inspect wher the leak is from.
Dan
Old Apr 6, 2005 | 01:12 PM
barry's Avatar
barry
If the filter has the metal screw on can, be very careful with it. They distort easily and then won't seal and really leak. They crush like a beer can.
Barry
Old Apr 7, 2005 | 12:54 AM
nealjpage's Avatar
nealjpage
Could it be that seal where the can mounts to the pump? A new filter comes with one of those seals. Might want to replace it anyways.
Old Apr 7, 2005 | 10:35 PM
cdherman's Avatar
cdherman
Autozone has the pump you want for about $25. The new autozone pump is non-rebuildable. Your pump likely has six big screws that hold the two halves of the pot metal housing together. These, older, pumps are rebuildable. But the rebuild kit costs $30.
The kits are not readily available -- I found mine at:
http://www.then-now.com/The_Cellar/cellar.htm
I will say -- I have a $25 Adavance one laying around, just for the moment the rebuild craps out. I think it would have been better to just give up on the old one. There were parts of the rebuild that didn't go so well. There is a bottom seal that is covered by a flange that is "staked" in place, and getting it all apart was a real pain.
If the local place tells you the don't have the one you need, then ask them to look for a 69 or 71. They are the same, but a lot of places have trouble earlier than 67 or so.
Old Apr 8, 2005 | 11:52 AM
99F150's Avatar
99F150
I have not gotten the pump off the truck yet, but is leaking from the bottom. Is there a vent hole on the under side?
Yes mine has the big screws that hold the two halves together.
Dan
Old Apr 8, 2005 | 01:25 PM
barry's Avatar
barry
The diaphram in the pump is leaking. Better change it soon before it craps out and leaves you stranded.
Barry
Old Apr 8, 2005 | 03:21 PM
44dwarf's Avatar
44dwarf
Better change the oil and filter at the time you change the pump gas can leak in to the motor and contaminate the oil.
44
rangergirl94
18
Jan 15, 2012 12:08 PM
Mad.Scientist
24
Aug 3, 2010 09:51 PM
Daman858
Oct 23, 2008 08:10 PM
tsherry
Sep 18, 2006 05:06 AM
jay9437
General Diesel Discussion
Jun 1, 2006 08:57 PM
