internal and external balancing
Old Apr 5, 2005 | 01:53 PM
lifted77f250's Avatar
lifted77f250
Lightbulb internal and external balancing
My friend just got a 77 460 from a lincoln. He needs a flywheel for it. I guess there is a difference in flywheels depending on balancing. How can you determine if its an internal or external. balanced engine.
Old Apr 5, 2005 | 03:20 PM
greenhighboy's Avatar
greenhighboy
If it is a 77 it should be internal. Look at the spacer behind the harmonic balancer. If it is smooth the motor is internal balanced. If it has a big hatchet looking weight on it the motor is external balance.
Old May 18, 2005 | 10:34 PM
T18skyguy's Avatar
T18skyguy
All 460's are internally balanced up to model year 79 I think. Please correct me if Im wrong.
Old May 20, 2005 | 08:27 PM
fasthauler's Avatar
fasthauler
My 77 460 is internally balanced.
Old May 21, 2005 | 02:49 AM
monsterbaby's Avatar
monsterbaby
your are not wrong, but to clarify they were all internally balanced up until 78. 79 model year was the first to be externally balanced.
