many zf conversion questions
Old Apr 7, 2005 | 07:02 AM
SD F350 99's Avatar
SD F350 99
In the picture I sent you, the driveshaft shown in the forground has the carrier bearing installed on it on the left side. On the truck that is the lead driveshaft and the carrier bearing goes toward the back of the truck. On my truck, there was a bracket riveted to the one of the rear crossmembers that dropped the carrier bearing to the correct level for driveshaft angles. I have it also. Just drilled it off when I changed mine to a 1 piece drivesaft for the x-fer case.
okwaho1650
Aug 26, 2014 08:16 PM
big ole ford
Jun 2, 2014 08:56 AM
PAwhiteboy
Engine Swaps
Oct 1, 2011 08:47 PM
rjitreeman0909
Jan 27, 2011 06:49 PM
rjitreeman0909
Jan 23, 2011 12:42 PM
