Lower Ball joint replacment help
Old Apr 4, 2005 | 06:03 PM
eyball's Avatar
eyball
I need to replace the right side lower ball joint on my 98 B4000 2 wheel drive truck. I do a lot of my own work on the truck but have never done a ball joint. Can someone tell me where I can find some step by step instructions on how to do this job? Thanks in advance.
Chris
Old Apr 4, 2005 | 08:07 PM
Rockledge's Avatar
Rockledge
The Technical Information thread at the top of the Forum has this listed as a reference:
Ranger Lower Ball Joint Replacment Thread
Old Apr 6, 2005 | 04:54 PM
eyball's Avatar
eyball
Thanks. I read over the thread and have a couple questions before I attempt to do this job. Do I need any special tools besides the press and the removal tool? I have the normal automotive tools. Also, I know I have to remove the cotter pin and bolt from the bottom ball joint but do I need to loosen up the top one? I only plan to replace the bottom ball joint.
Thanks again!
Chris
Old Apr 6, 2005 | 10:52 PM
munsokahn's Avatar
munsokahn
you have to take the top one out to get at the bottom. On my 83 ranger I used a 3/4 drive socket to pound it in...didn't have a press..make sure that the socket is close to the same size as the ball joint....I think it was 1 and5/16 inch socket that worked. If you can freeze your ball joint just before install will help a little. Remember if you ding the threads get a die to chase it or you will never get that nut on.....good luck.....
Old Apr 7, 2005 | 05:06 PM
eyball's Avatar
eyball
Does anyone know why the autozone part comes with two nuts? Also, how do I go about using the removal tool fork? Thanks!!
