Sponsored by: Kumho
tire size chart
Old Apr 4, 2005 | 04:33 PM
jimbob21rc's Avatar
jimbob21rc
Question tire size chart
does anyone know where i can find a tire size chart on the internet that i can print out.
Old Apr 5, 2005 | 04:13 PM
andym's Avatar
andym
Are you looking for gear ratio/rpm info? Or do you want to know the height of tires based on their size?
Old Apr 5, 2005 | 06:34 PM
jimbob21rc's Avatar
jimbob21rc
height and width of tires for example: 235/65/15 what that would be in inches, i want a chart to print out so that i can have it in my shop for reference.
Old Apr 5, 2005 | 06:42 PM
andym's Avatar
andym
Offhand, I don't know of one. You could make one up pretty easily, though, if you use Excel.
In fact, if you give me a range of sizes, I'll make one real quick for you. You can get a free Excel reader if you don't have access to the full version.
Old Apr 5, 2005 | 07:04 PM
SRD4X4's Avatar
SRD4X4
Don't want to hijack this,but I think the Rubber Manu. Assoc. has a printable version on there site.
Old Apr 5, 2005 | 10:15 PM
Mark Wenner's Avatar
Mark Wenner
The Tire Rack website has specs for the tires it sells, they vary slightly between tires of the same nominal size. Rim width affects the numbers, of course. I find it interesting that the standard rim width for measuring 32x11.5-15s is apparently 9 inches, though 15x9 rims seem to be pretty hard to find in the real world...
Old Apr 9, 2005 | 07:40 PM
yield2s's Avatar
yield2s
http://www.tirerack.com/tires/tirete...k/truksize.jsp
This should be what you need.
Old Apr 9, 2005 | 08:28 PM
aurgathor's Avatar
aurgathor
Just use a calculator such as:
http://www.1010tires.com/TireSizeCalculator.asp
Old Apr 15, 2005 | 08:32 PM
fyredrake's Avatar
fyredrake
An excellent tire size calculator (including difference in tire sizes and speedo readings) is located at:
http://www.eunos.com/tirecalc/
