tachometer & gauges
Old Jan 17, 2001 | 04:49 AM
hoot's Avatar
hoot
tachometer & gauges
I have a 91 F150 ext'd cab, 302,eaod trans.
My tach has developed a mind of it's own or has just become possessed. Problem: The tach wants to stay at 3400rpm until I cross that line. And even then it doesn't respond correctly. Just recently my other guages have started to read high. I believe this is most certainly an electrical problem. Sometimes it will go a week and all is fine. Have noticed that when it freaks out, it happens when I use my turn signal, cruise, brakes or windshield wipers. I can fix this but, have limited time to work on my truck. Any help or ideas would be greatly appreciated.
Thanks,
Hoot
Old Jan 17, 2001 | 01:40 PM
jakegypsum's Avatar
jakegypsum
tachometer & gauges
Hoot, It sounds to me that the voltage regulator for your guage cluster is on its way out. The guages run on a lower voltage. Usually the guages give strange readings, (sometimes above average readings), when this regulator acts up. I believe that it is just a plug-in type of thing. Good luck.
Jakegypsum // Ford fleet, soup to nuts.
Old Jan 21, 2001 | 07:47 AM
hoot's Avatar
hoot
tachometer & gauges
Thanks,
You wouldn't by any chance know where this thing is located?
Thanks again,
Hoot
Old Jan 21, 2001 | 02:22 PM
mrgford's Avatar
mrgford
tachometer & gauges
If I recall right I do believe it's located on the back of the dash cluster. But not for sure.
Mike G.
Old Jan 21, 2001 | 04:31 PM
zemus420's Avatar
zemus420
tachometer & gauges
Realslowww
Sep 2, 2014 03:00 PM
HOOTs95PSD
Aug 28, 2014 03:13 AM
totalrecall
Feb 6, 2008 08:42 AM
The Hoot
Jul 17, 2005 11:25 AM
