Offroad & 4x4
How does this sound?
Old Apr 4, 2005 | 12:00 PM
Pkupman82's Avatar
Pkupman82
Yesterday I traded a set of 351w heads, a 2wd C6 tranny, and a set of 351w exhaust manifolds for a set of Skyjacker 4/6 inch TTB drop brackets, BDS 4 inch springs and a set of blocks for 1980-96 F150/ Bronco. I think I got a sweet deal, what do you guys think?
Old Apr 4, 2005 | 12:31 PM
fishmanndotcom's Avatar
fishmanndotcom
not too bad but for those parts i prolly would've found a straight axle and notg have to worry about ttb drop brackets. just taller springs. and why couldn't you get rear springs instead of blocks?
good deal!
-cutts-
Old Apr 4, 2005 | 03:08 PM
Pkupman82's Avatar
Pkupman82
I have to say the IFS is starting to grow on me. I know both set ups ride very nice, I have to my IFS hasn't given me any problems (knock on wood). I like how the TTB works on uneven terrain. I won't be using the blocks in the rear because I already have 2 inch blocks plus the factory block and an Add A Leaf. If I do the 4 inch lift in the front, my truck will sit level. I have been concidering maybe later on in the future I might go up to a 6 inch lift. If I do that I will replace the factory leaf packs with springs arched for a 6 inch lift. Also I plan on installing dual shocks and traction bars.
Old Apr 4, 2005 | 05:52 PM
mustange70's Avatar
mustange70
that sure is a good deal, the heads and manifolds are common and cheap to find and the tranny is worth a bit but its more common then one thinks, so i would say you got a pretty good deal.
holdbeerwatchthis
Feb 16, 2015 08:42 PM
Don4.6
Nov 19, 2007 05:32 PM
wibblequikit
Jul 13, 2007 09:06 PM
broncoman79
Nov 10, 2004 01:36 AM
td351w
Jun 30, 2002 10:40 AM
