Need help asap 302 engine problems!!!
Old Apr 4, 2005 | 02:02 AM
mustang347gt's Avatar
mustang347gt
I just got the 302 all back together in my 1991 ford f-150 4by4.I replaced everything in the motor minus bearings and rings.The reason for not replacing the rings is there was a ridge in the cyl. but ran good in the donor.It was running great,then I was on my way to New York to pick a car up for a friend and my motor made a noise I was thinking a rocker or pushrod etc.Starting running on like 7 cyl.I starting having blowby and going through oil and oil into my breather and out my rear main seal.I went through about 10 qts in 1400 miles.It made it home seems to run better now and got blowby out my oil dipstick tube.It seems to have all its power still using oil mainly leaking I am thinking.I had to heads checked when I did the motor and a valve job done.The truck doesn't smoke out the tail pipe.What do you guys think happened?Think a ring broke?I was going to take the valve covers off and look but its running pretty good and no noise at all right now.Just the blowby from the oil dipstick tube.You guys think the motor is trashed if so I will build a new 306 for it.Please reply really need this fixed.
Old Apr 4, 2005 | 01:28 PM
mustang347gt
any ideas?
Old Apr 4, 2005 | 02:20 PM
312's Avatar
312
do a compression test.sounds like a bad cylinder.
Old Apr 4, 2005 | 02:49 PM
Lazy K's Avatar
Lazy K
I think you have a stuck or broken compression ring or rings on one cylinder. As suggested do a compression check.
Old Apr 5, 2005 | 10:44 AM
Kemicalburns's Avatar
Kemicalburns
why didnt you at least get the cylinders honed and rings installed. sounds kinda have assed dont you think. a compression test will tell ya for sure. let us know
Old Apr 5, 2005 | 11:21 AM
TigerDan's Avatar
TigerDan
As an engine runs, and wears, all the parts work and wear together, so to speak. When you do a valve job on a high milage engine, you are eliminating all the cylinder pressure leakage that occurs past the worn valves. This put more stress on the piston ring seal, and often you can get symptoms like you descirbe. I've even seen it happen just from replacing a blown head gasket. For a low buck rebuild, it's worth it to replace the rings and bearings as well. Use cast rings, not moly, as they will wear in better and conform to the out-of-round cylinders. But it's a lot of work for a very temporary rebuild, and it still may not seal very well. I think it's time for that 306 you mentioned. -TD
