Sponsored by: Real Truck
Is something wrong with this truck??
Old Apr 3, 2005 | 07:15 PM
jawmaw's Avatar
jawmaw
I have an 03 F250 with the 6.0 and auto transmission.
I just bought a 97 F350 regular cab, 7.3, auto tranmisson with an 84" Cab to axle dimension. The truck had a 12' van body which I removed and am waiting for my 12' flatbed dump to be built.
There are a two things I noticed and would like to find out if this is normal for the F350.
  • At 70mph on the interstate the F350 tachs around 2400-2500 rpm while my F250 only tachs 2000 rpm
  • The F350 shifts much more harshly than my F250 and when you let off the accelerator, the F350 de-accelerates much faster than my F250. The F350 actually feels like my F250 does when the tow/haul is in the tow mode. (I made sure the F350's OD is on)
Is this just the differences in the engine/tranmissions of the two trucks or is there something wrong with the F350.
Thanks in advance for any advice.
Old Apr 3, 2005 | 07:19 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
At 70 If You Are Running 4:10 Ratio Rear End It Is About Right
Old Apr 3, 2005 | 07:23 PM
mattd17's Avatar
mattd17
well, the two trucks should have different gear ratios in the rear ends.... just due to the fact that one is a 3/4 ton, and the other a 1 ton.
Old Apr 4, 2005 | 01:09 AM
etcetera's Avatar
etcetera
The gear ratio is causing the RPM difference. It doesn't matter 3/4 vs 1 ton. Pretty much all the ratios are available for both.
As for the shifting, the 350 is older, and I believe they have different trannies.
Eric
Old Apr 4, 2005 | 08:31 AM
chuck641's Avatar
chuck641
what you explained sounds normal. its most likely just the lower gearing in the 350
Jason
Old Apr 4, 2005 | 11:26 AM
emxmagnum's Avatar
emxmagnum
the shifts will feel different in the 97. the 97 still used the E4OD while your 03 uses the torqshift (5R100 i believe is the designation). unlike the E4OD, the torqshift is completely electonic. this could explain why it shifts smoother than the 97. the steeper rear end would also explain the faster deceleration.
Old Apr 4, 2005 | 06:59 PM
jawmaw's Avatar
jawmaw
Thanks Everyone. Your information is really appreciated!!
