engine will not start
Old Jan 28, 2001 | 04:40 PM
desperado_18_2000's Avatar
desperado_18_2000
well guys its back again.. fixed the tapping problem... turns out it was out of oil, and now it seems that it has some type of firing problem.. it will not start. it has spark, fuel, compression and is in time but will not start all the cylinders are responding to the engine roll over.. i'm undecided if its the timing chain or the pickup coil in the distributor.. any suggerstions would be apprecaited
Old Jan 29, 2001 | 12:38 AM
PAUL_2's Avatar
PAUL_2
Its always best if you tell us what truck , engine etc you have before anyone can offer any help .
Old Jan 29, 2001 | 07:15 AM
billyb's Avatar
billyb
check the timing to see if chain has jumped. you can spend all day getting fire and fuel and occasional spitting and sputtering with the chain jumped or stretched. any questions on how to do this, just ask and you'll get replies. lol.
Old Jan 29, 2001 | 10:21 AM
desperado_18_2000
351c my mistake.. iwas in a hurry when i posted... and i didn't know it was out of oil.. the dipstick was too short so i couldn't tell if it was or wasnt..but thats a diff story
anyhow.. like i said it gets fire and gas.. everything seems fine.. but the color of the fire is white instead of blue... timing chain could have stretched.. at least i can fix this and maybe make a couple guesses.. and not spend my paycheck trying to fix it like some old CH**y..
Old Jan 29, 2001 | 12:26 PM
slikness's Avatar
slikness
Try the coil first, it doesn't take long to check it out and eliminate that from the problem list. I then would suspect my distributor. There are ways that you can check the mag pickup or other components of the distributor.
'82 F150 2WD w/351W (orig 300 I6)
Slik
Old Jan 29, 2001 | 03:55 PM
desperado_18_2000
well i replaced the pickup coil in my distributor.. ive changed the coil also.. alas no response from the 351..
Old Jan 29, 2001 | 04:44 PM
otto's Avatar
otto
