Alluminum Intake
Old Apr 2, 2005 | 04:23 PM
Poulsom's Avatar
Poulsom
Alluminum Intake
Hello I am in the midst of installing an edelbrock alluminum intake for a 1985 ford 351 Windsor HO and I don't know the torque specs for the intake. Does anyone know?
Old Apr 3, 2005 | 03:03 AM
Ford_Six's Avatar
Ford_Six
In the range of 20ft/lbs, I don't know the exact number off hand. Generally, tight with a standard wrench.
Old Apr 3, 2005 | 02:31 PM
baddad457's Avatar
baddad457
NO more than 20 ft/lbs, some times less, like around 15-18 ft/lbs. Start in the middle and work outward, in a criss-cross fashion.
Old Apr 3, 2005 | 04:02 PM
fordxxx's Avatar
fordxxx
20 lb'ft is correct. Be sure to be back and torque them down again after you have run the motor...you will find that they are all down to about 10 lb'ft.
Old Apr 3, 2005 | 07:13 PM
baddad457's Avatar
baddad457
I torque mine 5-6 times before running the engine, and not at all afterward. You will likely find that 20 ft'lbs is pushing it on an aluminum intake, especially at the 4 corner bolts.
