I have a 1997 F-350 with a 351 Windsor that does not have a computer in it. It does however have a rev limiter which makes it cut out at 95mph. I am wanting to disconnect the rev limiter but I am not exactly sure how to go about it and do it right. Can anyone help?
Look I am looking for a couple of wires. You are not helping out baddad457. There should be two wires to cut that lead to the distributor but I am not sure which two wires to cut. If anyone knows which wires to cut I would be greatly appreciative.
Your computer is probably under the kick panel or look under the hood, on the drivers side under the master cylinder area. You have to have a computer to run EFI. They do make chips for these and they generally get rid of the speed limiter with the upgrades.
Theres no magic wire to cut.You'll need a chip or eec tuner to remove the rev/speed limiter.The computer in my truck is behind the drivers side kick panel(Have to remove the e-brake to get to it).You may want to check there
