u joints
Old Jan 31, 2001 | 09:45 PM
bige53's Avatar
bige53
u joints
I changed my tranny to a t18 from the 3 speed/od.had to change driveshaft but the u joints are not the same size. large on chunk small on driveshaft.Bought a special u joint/odd very odd.Is there a yolk for the chunk that will match the shaft (SMALLER} 331 GEARS
Old Feb 1, 2001 | 08:05 AM
Trail_Rider's Avatar
Trail_Rider
u joints
>(SMALLER} 331 GEARS
When you say "chunk" are you talking about the trans? If so you should be able to swap out tail shaft yoke and use the one from the 3 speed. I had to do that on a similar tranny swap. It was a bolt in.
Trail Rider
Old Feb 1, 2001 | 05:54 PM
billyb's Avatar
billyb
u joints
check with junkyards or consult a hollander interchange book to find out what tranny might have same size u-joint . you might be able to get a parts guy to figure it out using the u-joint parts book. i know on the f150 you can have 1-1/16 or 1-1/8 u joint cups, so it should be easy to find out what will work.
ultimately, you may have to have yoke welded on your driveshaft.
Old Feb 1, 2001 | 06:22 PM
bige53's Avatar
bige53
u joints
The chunk is the ring gear and pinion housing on the axel.The u joint on it is larger than the driveshaft.had to use a ******* u joint.
Old Feb 2, 2001 | 06:58 PM
Phillip Guidry's Avatar
Phillip Guidry
u joints
Without knowing the exact year model of your truck, or, what truck the driveshaft came from, I would say you need a part # 5-1204X Spicer joint in the rear and a 5-213X / 5-1203x JOINT the front. Identifying U-joints and where they can be used is kinda my specialty (17 years in parts w/ driveline building experience)so if you have trouble, feel free to contact me.
Phil
Old Feb 3, 2001 | 12:07 AM
bige53's Avatar
bige53
u joints
I am going to try the salvage yards to try to get this corrected before I do any thing else.The truck is running ,but I dont like anything thats not correctly repaired.Thanks to all for the help.Phil if I cannot get this corrected I will contact you later.Thanks again guys!.
Old Feb 3, 2001 | 10:22 AM
bgodkin's Avatar
bgodkin
u joints
