Latest Flash 2003 ??
Old Apr 1, 2005 | 10:08 PM
BLACK350/6.0L's Avatar
BLACK350/6.0L
What is the latest flash out on the street for the 2003 6.0L's and what is it supposed to remedy? Thanks in advance!!
Old Apr 2, 2005 | 06:25 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Do you know the flash number
Old Apr 2, 2005 | 07:27 AM
gonnasellit_temp's Avatar
gonnasellit_temp
The latest flash for non California 03's is -FTE. This one seems like a keeper. Better mileage, more power. It really made my truck come alive again.
Old Apr 2, 2005 | 12:42 PM
BLACK350/6.0L
I am trying to find some info out for a friend. Is there a website that lists the latest flash and what it remedies he had this done a week ago. What is -fte flash?
Old Apr 3, 2005 | 10:33 AM
gonnasellit_temp
The -FTE is the last three letters of the code number for the latest flash program for the 03 6.0L. According to my Tech the flash addressed some problems with cold idle and surging, reduced turbo lag, and appears to help fuel mileage among other things. I haven't seen any official release from Ford as to the purpose of the flash, however it made a tremendous difference in my truck which formerly had the December 03 flash. The performance of my truck after the flash is very similar to what it was with the original program installed in the truck from the factory prior to the mandatory recall flash due to non compliance with emissions standards. Truck now idles quieter due to EGR opening at idle, has better throttle response, and increased fuel mileage. Highway mileage at 70 mph is now 19.5 - 20.7 as calculated on a recent 1200 mile trip with 4 adults and luggage. I also averaged just under 17mpg on a 550 mile trip towing a flatbed with a small car on it. I couldn't be more pleased with it.
Old Apr 3, 2005 | 12:22 PM
LaredoF350's Avatar
LaredoF350
The latest number is 3U7A 12A650 FTE. I had an original unflashed '03 before having this done because of terrible romping issues. The truck runs just like before w/o the romping and start-up run quality issues. Mileage didn't change much from original but its hard to say because of the lighter winter fuel we have been running but I know for sure it isn't better than the original mpg!! The pilot injection is gone just like in the other flashes and this doesn't bother me at all, but the loss of the tow-haul performance does. Compared to the original program, the glow plugs don't stay on as long on a warm start if at all and the overhead fuel mileage display now reacts quicker --> more like an instantaneous mpg but not quite (kinda half way between average and instantaneous).
Old Apr 3, 2005 | 01:29 PM
SBV45's Avatar
SBV45
It depends what flash that 2003 is on. Some flashes fixed things and broke something else. The Oct 03 flash broke performance, fuel economy. The latest flash 3U7A-12A650-FTE (for 03 truck with auto trans non-California) fixes some idle issues, delay, performance and some shift issues in tow/haul mode. It is a pretty good tune.
Old Apr 3, 2005 | 03:37 PM
digger52's Avatar
digger52
SBV45 , I had the latest flash 3U7A-12A650-FTE installed the end of Feb. and traveled 2500 mi. pulling 3000 lb. (min. load other than running into pretty good head wind to and from, ave. 15.2 mpg. I can live with that but one question? why would it take the down shift out of 1 st. and 2 nd. and also hesitate after shifting from park to drive . Talked to different ones and altogether different stories, reading some of your posts I take it your pretty knowlegable about this new flash , thanks - just wondering.
Old Apr 3, 2005 | 07:38 PM
DHochman's Avatar
DHochman
Will this flash help with with a 2003 6.0 stick? The truck has no power when in first or creeper gear when cold. I mean NO power! Its hard to get it going on a grade with moderate weight without stalling. The Ford mechanics want to pull the tranny appart because they are not sure what is causing the problem. They are getting any info from the computor that helps with the diagnosis. The truck has never had a flash or any problems. It has 18,000 on it. It may be my own fault because I asked that the truck not be flashed unless it had to be.
Thanks,
Dave
Old Apr 3, 2005 | 08:37 PM
tristankc's Avatar
tristankc
I had the last flash done on my '03. It runs great. Slightly better fuel economy. The only thing I am unhappy with is the way the tow/hual works now. It works, but feels week (downshifting). Sometimes it does not seem like it hits all of the gears when downshifting. Pre flash, you KNEW when it downshifted. Now you really need to pay attention. It is not nearly as easy to stop a 12K trailer now.
Old Apr 4, 2005 | 05:10 AM
SBV45's Avatar
SBV45
Digger52, I haven't done too much towing so I don't know about the downshift issue. I will check it out. As far as the hesitation from Park to Drive, I have not experienced that problem. Here is a service bulletin on that:
Harsh or Delayed Forward or Reverse Engagement:
This could be caused by a sticking line pressure control (PC-A) solenoid. Typically the line pressure will be fluctuatiing wildly (up to 500 PSI!). To service, first remove and insdpect the external cooler line filter. If it contains fine gray metalic debris. If metal is found, the source is most likely a defective revese planetary pinion shaft that is coming out of the carrier and contacting the case or adjacent components. The transmission will need to be disassembled and repaired as needed or replaced. Broadcast Message 3250
If little or no debris is found replace the line pressure control solenoid with P/N 4C3Z-7G383-AA. Broadcast Message 1586/SSM 17874/18051
This repair will require removing the solenoid harness, so a new harness sealing o-ring (P/N 3C3Z-7Z276-AA) will need to be installed. In some cases the solenoid body will need to be removed from the trans to remove the harness and solenoid. In this case the solenoid body gasket (basic P/N 7C155, trans tag number needed) will be needed as well. Note: Do not loosen the 10mm head bolts on the solenoid body. Only loosen the 8mm head bolts.
If the solenoid has been replaced and the condition it still pressent, suspect a contamination issue of the solenoid or a sticking pressure relief valve.
Ford has stopped putting out the information on flashes that they used to put out. The dealers service can't even get the info on what a flash fixes.
Old Apr 4, 2005 | 10:40 AM
LasVegas F250's Avatar
LasVegas F250
I have a 2004, it was flashed just last week. Increase in fuel milage 2mpg, But preformace down slightly. Pulled the 5th out of storage for a wash and really noticed the tow/hual mode. It seem to be just as Tristankc said. WEAK!!! Before you barly needed to use the brakes but now have to sit on them until I stop.
Heckler
Aug 31, 2010 06:00 AM
rcorcich
Jan 21, 2010 09:38 PM
fridgeguy
Sep 23, 2006 05:30 PM
