Help with shock selections
Old Apr 1, 2005 | 10:02 PM
tater_51's Avatar
tater_51
Doesn't seem to be much out there in the way of shocks for a 1975 F-100 4X4 (stock). Looking for some suggestions for shock replacement, any help would be appreciated. Thanks
Old Apr 2, 2005 | 03:51 PM
LxMan1's Avatar
LxMan1
Gabriel makes good shocks.
Old Apr 3, 2005 | 01:05 AM
roger dowty's Avatar
roger dowty
Should be able to get them at most if not all parts stores. What is it that you are looking to do? you can get some stout gas/oil that will stiffin you up or just a oem type to keep the ride a bit smoother but won't help with handling or pounding the trails. I need to replace both rear and front and may go with an air set up or ajustable so I can tune my ride a bit better or adapt to a load. May also just go with a stock shock and get air bags or a combo or......I agree with lxman- gabriel makes a good shock. so do others.
Old Apr 4, 2005 | 10:53 PM
plowpusher's Avatar
plowpusher
Monroe magnums I know NAPA carries them
Old Apr 8, 2005 | 07:03 PM
stroker1's Avatar
stroker1
The rancho RS9000 is a good shock. It has a dial adjustment for five settings,however i am not sure if they have a setup for the f100.
Old Apr 8, 2005 | 11:10 PM
Matts72's Avatar
Matts72
Rancho, KYB, Monroe, Gabriel, Edelbrock... they all make shocks for that truck.
FordBoy2012
1997 - 2003 F150
Apr 14, 2013 04:34 PM
hired_gun
Apr 10, 2004 01:38 PM
Jakebrake
Aug 8, 2002 08:20 AM
