Buying a '93 4x4
Old Apr 1, 2005 | 05:43 PM
jasoncar40's Avatar
jasoncar40
Buying a '93 4x4
I was at a Ford dealership today that I had never been to before and they had a 1993 F-150 XLT, Short Box, 4x4 w/ manual hubs, and a 5.0 V8, 5-speed. It has 150,000 miles on it, but I took it for a test drive and it drove pretty well.
The only questions I have are what do some of your guys trucks read for oil pressure? After I got this one warmed up, it only read between the middle of N and the top of O in <st1:city><st1 ="">normal</st1>l</st1:city><st1:city></st1:city>. Also, have any of you needed to adjust/replace the synchronizers in a 5-speed? The reason I ask is that during shifts, the transitions between the gears seemed a rougher than any other 5-speeds I have driven?<o =""></o>
<o =""></o>Any other information about things I should look out for from people would also be appreciated.
Old Apr 1, 2005 | 06:32 PM
andym's Avatar
andym
Read up on the oil pressure gauge here. The position of the needle means absolutely nothing.
The five speed in my truck shifts great at 145,000 miles. All the synchros work great. FWIW.
Old Apr 2, 2005 | 09:22 PM
Popa Tim's Avatar
Popa Tim
What the hell.. the dealer probably wont know that about the oil pressure; so use it to your advantage. Tell him it should read in the center so the engine is showing signs of wear. And since its real expensive to change it in a 4x4 have him knock off another few hundred...
hehehe
Old Apr 2, 2005 | 09:38 PM
JSNYDER576's Avatar
JSNYDER576
You Can Have Them Knock Off A Couple Hundred More For Synchros Too. But Before You Actually Change Them Out Change The Oil In The Tranny.
IraTodd
All Things Towing
Mar 27, 2007 10:17 PM
No-Tyme
2004 - 2008 F150
Feb 9, 2007 06:41 PM
78f-150Supercab
Texas Chapter
Nov 1, 2006 03:26 AM
Hodaka
1997 - 2003 F150
Feb 14, 2005 08:09 PM
