Back brakes
Old Apr 1, 2005 | 12:01 PM
tad32287's Avatar
tad32287
Question Back brakes
There is nothing there, so I got a the backing plate, drum, and some odds and ends. I was wondering what are the names of the parts I am going to have to look forward to buying to get it all together.
Old Apr 1, 2005 | 12:53 PM
85F_150driver's Avatar
85F_150driver
you will need the wheel cylinders, the self adijusting hardware, a hold down kit including springs, and also the parking brake struts & cables.
A haynes manual will show you all you need to know.
Old Apr 1, 2005 | 12:56 PM
tad32287's Avatar
tad32287
Got the manual at home infact, at school right now and wanted to look up some prices, thanks.
Old Apr 2, 2005 | 09:45 PM
hermangarza's Avatar
hermangarza
what out as there is diffrent kind of wheel cylinders.
Old Apr 4, 2005 | 12:15 PM
85F_150driver
the only difference is if you try to get them from autozoo or oreilly's. I have found that napa and other quality parts stores have they exact ones you will need.
Old Apr 4, 2005 | 01:59 PM
hermangarza
so napa would be the best place to get the right ones? ill be quite a ride but if its worth it why not
Old Apr 4, 2005 | 10:50 PM
85F_150driver
when i had to get wheel cyls for my 83 crown vic, same axle as my truck, i went to autozone and oreillys and neither fit into the backing plate correctly so i took em back and went to napa and it was perfect fit. It was actually $3 cheaper then autozone and 6 cheaper then oreillys.
