little problem
Old Apr 3, 2005 | 08:43 PM
proud_redneck's Avatar
proud_redneck
little problem
i put a new holley carburetor on my 1980 Ford F350 with a 460, and it idles pretty high, probably at about 900 or a little more. when i drove it for about 5 to 10 minutes, and as soon as i shut it off, about 5 seconds later, it made a loud pop, that sounded louder than a shotgun, and i saw a flame come out the exhaust, and i know this isnt good, so whats your ideas?
Old Apr 3, 2005 | 09:13 PM
proud_redneck
anybody know what the carb should be tuned to, or if its just a matter of running a little too rich?
Old Apr 3, 2005 | 11:21 PM
kermmydog's Avatar
kermmydog
I have a 600CFM 4160 Holley on mine 460 and it worked great out of the box. What Holley do you have? Have you tried setting the idle down to about 600 RPM. Sounds like too high of idle was your shotgun blast.
Old Apr 4, 2005 | 11:24 AM
MRStace84's Avatar
MRStace84
Did you set your floats. My 390cfm came from the factory witht the floats set as low as they would go. Set the floats, set the idle mixture and idle. If they doesn't work maybe you need to re-jet
Old Apr 4, 2005 | 10:19 PM
proud_redneck
my buddy set my floats, and the fuel mixture, but i messed with the idle speed, cuz when its cold, every time i put it in drive or reverse, it drops to a really low idle and sometimes dies. so i just set the idle hella high. this carb is new to me, but my buddy had it on a camaro with a 396. i dont know what idle speed will keep it running under load(in gear.) does anybody else have that little problem?
Old Apr 5, 2005 | 01:15 AM
proud_redneck
do you think i just need to lean it out and let the idle speed down? its just that when its cold, it will stal as soon as i put it in gear
Old Apr 5, 2005 | 01:24 AM
pfogle's Avatar
pfogle
Are you using the choke when it's cold? If not that will make it die when you put it in gear.
Old Apr 5, 2005 | 01:48 AM
proud_redneck
i do use the choke until it starts warming up, but should i drive the first mile or so with the choke closed, to make sure it warms up good? i dont know what the fuel mixture should be set to, but my friend who owned it before me used it on his camaro, and so he did the tuning on it. i have a manual choke on it, cuz i dont trust electric chokes. could a possible vacuum leak be the problem? cuz i thought that was it, but i couldnt find any bad vacuum lines.
MC5C
Jun 24, 2012 12:53 AM
4x4jedi
Jul 19, 2010 04:26 PM
brownh20GM
1997 - 2003 F150
Mar 8, 2010 01:01 AM
Redneck1465
25
Jan 17, 2009 12:42 AM
99_F250_SD
May 24, 2008 07:25 PM
