walker pipe ?'s
Old Apr 1, 2005 | 11:15 AM
monsters's Avatar
monsters
walker pipe ?'s
anyone know the part # for the efi walker downpipe? and where I can order one?
Old Apr 1, 2005 | 12:35 PM
dgpruitt's Avatar
dgpruitt
Walker Downpipe - Part # 45166
This is the "Y" pipe I believe (I hope). I recently ordered this from Rock Auto (www.rockauto.com), $50.79, it is supposed to arrive today...
Daniel
Old Apr 1, 2005 | 01:09 PM
wickymustang's Avatar
wickymustang
That is just the y pipe or is it with the cat as well?
Old Apr 1, 2005 | 01:31 PM
5_labsownus's Avatar
5_labsownus
45166 is just the down pipe without the converter. It also has an O2 sensor bung.
Old Apr 1, 2005 | 07:14 PM
wickymustang
Not to hijack but I am planning on ordering that and a highflow cat. I have a 95 4.9L, so I need one with an air injection port, but my question is can i turn the cat 90 degrees along its longitudinal axis so it doesn't hang as low as the stock cat?
Old Apr 2, 2005 | 07:35 AM
5_labsownus
It can be turned on an 45 and not hang as low.
Old Apr 2, 2005 | 09:22 AM
dgpruitt's Avatar
dgpruitt
Mine arrived yesterday. Here's a picture:
Notice the O2 sensor port mentioned in other posts. I don't need this port. Any idea what size and type of fitting I need to plug this up? Also, would I need some type of sealant on the threads, or would that not be necessary?
Old Apr 2, 2005 | 10:56 AM
wickymustang
5_labsownus, why only 45*? Wouldn't it fit up tight aginast the body if I turned it 90?
Old Apr 2, 2005 | 05:41 PM
5_labsownus
It will turn 90 deg but it will be too close to the tranny/transfer case and cause too much heat in them.
The O2 bung can be pluged with an old O2 sensor or have a shop weld the hole closed before install.
Old Apr 2, 2005 | 09:10 PM
wickymustang
Even with a 2wd 5spd it will be too close?
Old Apr 3, 2005 | 10:22 AM
5_labsownus
You may test fit the cat to see and you may have room to move it back a few inches but keep it away from things that don't like heat!
