Fly Wheel Torque help
Old Apr 1, 2005 | 06:39 AM
toolebox1's Avatar
toolebox1
Red face Fly Wheel Torque help
I thank all you guys that have helped me out, now I need the torque for the fly wheel so it won't come off again..
Old Apr 1, 2005 | 11:41 AM
4tl8ford's Avatar
4tl8ford
What Engine?
Old Apr 1, 2005 | 05:27 PM
mtflat's Avatar
mtflat
Originally Posted by toolebox1
I thank all you guys that have helped me out, now I need the torque for the fly wheel so it won't come off again...
Ok, give us the story - sounds like it should be a good'n
btw, flathead is 75-85 for the flywheel bolts
Old Apr 1, 2005 | 05:38 PM
toolebox1's Avatar
toolebox1
1960 292 4 speed transmission
Old Apr 1, 2005 | 06:52 PM
Madathlon's Avatar
Madathlon
OMG.. What happened? I have to hear this one
Old Apr 1, 2005 | 07:08 PM
4tl8ford's Avatar
4tl8ford
toolbox
My BOOK doesn't cover that engine
Old Apr 1, 2005 | 09:43 PM
toolebox1's Avatar
toolebox1
Ok, here is the story...
I bought this 1960 f-350 tow truck from a guy who had no clue about these trucks when he started it up the engine made a horable noise and started to leak anti-freez out the water pump. I told this guy to shut down the engine. The look on this guys face was like someone stole his best toy, Anyway I got it less than what he was asking. I towed it home and changed the water pump and it ran fine every thing worked on it too, for 5 months till one day I was moving it into the drive way when all hell broke loose from under the floor board.
I parked it in the driveway and looked to see what happened. All the flywheel bolts backed out and came loose from the crank shaft and tore up all the bolt holes. So I have been replacing the crank shaft and flywheel for the past few days that is why I have been asking for all the torque specs.
Once again thank you all for the help.
Craig
Old Apr 1, 2005 | 10:12 PM
ALBUQ F-1's Avatar
ALBUQ F-1
As lucky as you are, you should play the lottery! You could have easily lost your legs
Old Apr 1, 2005 | 10:36 PM
toolebox1's Avatar
toolebox1
Well I am in Reno Nevada...
If you want to see my tow truck check out my Gallery.
Old Apr 2, 2005 | 01:01 AM
mtflat's Avatar
mtflat
Some story - like Ross, I'm glad you survived to tell the tale.
I've got specs for flathead V8s from 32-53, and all engines Ford produced from 64-95. All references to flywheel torque settings for all the above engines is 75-85 ft/lbs.
edit: Just found a reference among my collection - 292 Y-block flywheel is same 75-85 ft/lbs.
Old Apr 2, 2005 | 06:18 AM
toolebox1's Avatar
toolebox1
Thanks Man, I do appreciate the help!
