How many miles between oil changes?
Old Apr 2, 2005 | 09:28 PM
huntercgr's Avatar
huntercgr
http://www.blackstone-labs.com/
seems to be everyones favorite.
Old Apr 3, 2005 | 01:03 AM
MobeyDick's Avatar
MobeyDick
I don't know on my 05 6.0 how I will do it yet, most likely every 10,000 miles with Mobil 1 Syn.!! I used and will cont. to use Mobil 1 Syn in my 01 7.3 and I put 87,000 miles on one oil change with it "during warranty period". Changed Filter and replaced lost oil every 10,000!! Never had an oil related problem using Mobil 1!! Put 380,000 miles on a chevy 6.5TD with it!! Put 247,000 on a 4.3 chevy with it and you could open the filler cap and the motor looked like it did when it came from the factory!! Yep, I was a GM man!! I think I have owned my last GM product!!
Old Apr 3, 2005 | 05:32 PM
GarageDoc's Avatar
GarageDoc
PM is the key to reliabilty. Myself, I do 3k to 4k oil changes and filter. In reliabilty we quite often exceed the manufactures reccomendation. Sure you can always test a sample after 7 and/or 10K but if the test comes back with bad news...the damage is already done.
Old Apr 3, 2005 | 06:40 PM
MobeyDick's Avatar
MobeyDick
If I did that I would have to change the oil every 2 1/2 weeks!! That's not going to happen!!
Old Apr 3, 2005 | 06:47 PM
zenitram's Avatar
zenitram
I have the lifetime oil change, so its every 3K for me.
Old Apr 3, 2005 | 07:47 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
lifetime oil changes on a PSD would be great. Just the cost of oil and filter with every discount I can get it still runs $42 per change. You got a GOOD deal.
Old Apr 6, 2005 | 01:02 AM
dPrasse01's Avatar
dPrasse01
driving daily across country as a Hot-Shot ... most miles towing , many dead-heading to the next load , idling to keep me warm at night ... change every 5,000miles ...basically weekly ... oil changes happen on the road where ever 5,000 miles happens .... I change many times at Sagitt Ford in near Seattle ... they laughed that they knew they had good advertising but never had someone drive from IL for an oil change ... funny guys ! But they are definitely a "Power Stroke" dealer ... dealer full of accessories and goodies for the PowerStroker ..... they get my business everytime I hot shot to the Seattle area ...
Old Apr 6, 2005 | 01:27 AM
dPrasse01's Avatar
dPrasse01
Originally Posted by 3/4ER
The same engine (VT 365) in an International truck has a 10,000 mile oil change recomendation
Also note that the highest rated VT365 is 230 HP , so Ford is already squeezing an additional 100 HP at 1,000RPM higher than their International counterparts ( I still think that extra 100 hp is part of the problems Ford 6.0s are having ...add a chip and now you are 200 hp over the designers/manufacturers own version ....)
also notice the VT365 has a 19 quart oil system ...
I'd say 5,000 miles for all changes is about right ...unless all your miles are unloaded , warm engine highway miles , then maybe the 7500 mile change would work ok .... these puppies are a tad too expensive to try to save a few dollars running "old oil" in them .....
Old Apr 6, 2005 | 08:43 PM
Sark's Avatar
Sark
Talking
Originally Posted by drfbuster
I know this topic has probably been beat to death but how many miles do all on this forum go between oil changes?
I drive about 15,000-20,000 miles a year and it mixes between city and hwy miles...
I have been changing my oil on my 04 6.0 every 4,000 miles and it seems like I'm changing it every month.......Thanks for any info.....drf
I have a 04-F350, CC, DRW, Lariat, 6.0, 13,600+ miles. I tow a 35 ft. 1/5 wheel & have changed the oil every 4,000 using Delo 15/40. I don't want to take the chance on extended oil changes. Better safe than sorry!!
Old Apr 6, 2005 | 08:53 PM
SBV45's Avatar
SBV45
5,000 and 7,500 are not extended oil changes. 5,000 is what Ford recommends for "severe" duty.
Old Apr 7, 2005 | 11:07 AM
Sark's Avatar
Sark
Red face
I guess extended is a matter of opinion. For 15 yrs I changed the oil on my 89-F350, CC, DRW, 460ci every 3,500 miles. My 1965 Corvette, 396ci 425HP, was changed every 1,500 miles. All my vehicles go overy 100,000 miles without engine problems & I'm definitely not easy on them.
Old Apr 7, 2005 | 01:24 PM
deacjrt's Avatar
deacjrt
Every 5K. I rotate tires, change oil and filter, drain HFCM and if the 5k falls in conjunction with the 15K fuel filters I'm in heaven. I think these badboys are fairly easy and fun to do this maintenance on.
Old Apr 7, 2005 | 02:11 PM
  #28
juniorf350's Avatar
juniorf350
i change oil between 3000 and 3500 miles. useing mobil delvac 1300 super.
Old Apr 7, 2005 | 04:26 PM
  #29
Daryl Hunter's Avatar
Daryl Hunter
I change mine at 7,500 miles if I haven't been towing the trailer but have been doing more highway driving than usual.
If I've done mostly in town driving and pulled the trailer a few times then I change it at 5,000 miles.
Old Apr 7, 2005 | 06:33 PM
  #30
tinytrixie's Avatar
tinytrixie
I found this link on Blackstone web site, there is some debate elsewhere that changing synthetic too often causes increased metal in reports, sounds odd to me. Here is the link:
http://neptune.spacebears.com/cars/s.../oil-life.html
It's like you are damned if you do & damned if you don't.
Here is another about the newer oils:
http://www.heavydutytrucking.com/2003/03/090a0303.asp
pilotshot
6.4L Power Stroke Diesel
40
Jul 21, 2018 10:30 AM
fridgeddiesel
18
Feb 9, 2016 12:34 AM
allcool
6.7L Power Stroke Diesel
Nov 19, 2015 07:11 PM
finitetime
23
Mar 10, 2011 08:56 PM
Sayer Lane
1997 - 2003 F150
Jun 13, 2010 10:12 AM
