Why does it ping?
Old Mar 31, 2005 | 03:59 PM
redcarnut's Avatar
redcarnut
Question Why does it ping?
I have a '89 F150 2WD with the 5 litre V8 and AOD tranny.
It starts and runs well around town and at low speed, but on the highway it pings when under load. If I stomp on it and it shifts down,it accelerates reasonably good. Power at less than full throtle is poor. I can't use overdrive on the highway even with an empty bed. It will loose speed, ping and shift down even on the slightest grade.
I have replaced the knock sensor, throttle position sensor, oxygen sensor and even put in a rebuilt ECM, all with no results.
Any ideas will be appreciated. Tom
Old Mar 31, 2005 | 04:03 PM
andym's Avatar
andym
Is the computer throwing any codes? Have you checked the base timing? It should be set at 10 BTDC with the SPOUT connector removed.
Old Mar 31, 2005 | 05:33 PM
MRL123's Avatar
MRL123
I agree with Andy M. - Check your timing 1st as that is one of the major causes of pinging. Could be too much deflection in the timing chain - what kind of miles do you have on the motor? Also could be the quality/grade of gas. Have you tried running a tank of midgrade fuel just to see if the pinging stops? Your performance, or lack of same, tends to lead me back to the timing matters though. Start there and post back.
Cheers!
Mike
Old Mar 31, 2005 | 06:33 PM
924x2150's Avatar
924x2150
I believe there is a knock sensor screwed into the side of your block, it senses knocking and tells the computer when to adjust the timing. You definitely have some timing issues. Try www.fordfuelinjection.com for the basics.
Old Apr 1, 2005 | 06:32 PM
redcarnut's Avatar
redcarnut
Checked timing with spout jumper removed and it came up about 7 degrees BTC. Did not increase to 10 as I thought that would make it worse.
To adjust timing do you loosen clamp and twist the distributer just like on older models?
Tom
Old Apr 1, 2005 | 06:48 PM
Argo's Avatar
Argo
What is your fuel pressure at operating speed? Could be a bad fuel pressure regulator.
Old Apr 1, 2005 | 07:06 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
when was the last time you changed the fuel filter?
Old Apr 1, 2005 | 10:47 PM
Argo's Avatar
Argo
Duh! Why didn't I think of that?
Old Apr 1, 2005 | 11:04 PM
924x2150's Avatar
924x2150
Remove the spout connector, loosen distrib. clamp, and adjust distributor to 10 Btdc or as indicated by the emissions sticker under your hood. Retighten dist. and reconnect spout. The timing will be controlled by the ECM after that and you no longer need to worry about any further mechanical timing adjustments.You must try and see if there are any codes just in case. try fordfuelinjection .com
Old Apr 2, 2005 | 02:43 AM
Ponyracer's Avatar
Ponyracer
what about bad gas? does it do it with both tanks?
could also be a dirty airspeed sensor at the intake. I dont think there are going to be any codes as he didnt say the check engine light came on. you might change the fuel filter also. a restriction in the exhaust at the cats or muffler can cause a ping also.
Old Apr 2, 2005 | 11:57 AM
wdb1971's Avatar
wdb1971
if you put low grade gas in your tank that will cause a ping
Old Apr 2, 2005 | 01:56 PM
924x2150's Avatar
924x2150
My 92 is throwing codes, they are flashed at KOEO test. I never see any check engine light, not all errors make the light come on.
Old Apr 2, 2005 | 08:58 PM
Classic F-250's Avatar
Classic F-250
Ping....
Here is a shot in the dark, is your radiator original. Well my 1990 F-250 5.0 5spd stopped pinging after a HD radiator swap. I guess it had somthing to do with the engine running hotter, also with a load on the truck or if I where going up a certain grade it would also ping .....
