No Acceleration
Old Mar 31, 2005 | 03:22 PM
bbuffalo's Avatar
bbuffalo
Thumbs down No Acceleration
Have a 2004 F250 w/30,000 miles. Problem is intermittent and being so, the dealer cannot fix what does not show up on the computer. When the truck is started, it runs but you hear no clatter, if you press the accelerator you get nothing. Eventually it will die. When restarted everything is fine. Happens about every 4-5 weeks. If the dealer would just leave a recorder on the truck for me, I could catch the problem. Any ideas. Starting to really get pissed. Thanks
Old Mar 31, 2005 | 03:26 PM
SBV45's Avatar
SBV45
Disconnect your EGR and see if the problem goes away. Turn off the engine and ignition before disconnecting EGR. If the problem goes away, it is your EGR sticking open. It could also be a problem with wire chafing.
Old Mar 31, 2005 | 03:42 PM
bbuffalo's Avatar
bbuffalo
The problem is so random. Do I need to wait till it happens before i try this? I guess the only way i will know if it is fixed is if it never happens again. Or can i disconnect it anytime w/engine & ignition off and reconnect it. They have already changed out some wiring harness. The dealer has put 473 miles on my truck the past 2 weeks trying to duplicate this problem with no success. So i am back to square one. Thanks
Old Mar 31, 2005 | 09:11 PM
SBV45's Avatar
SBV45
I would disconnect it now with the engine/ignition off. See if it happens again.
As for chafing, see the pics at this link for wire chafe pics website
Old Apr 4, 2005 | 05:14 AM
bbuffalo's Avatar
bbuffalo
When you disconnect it, do you leave it disconnected or just reconnect it? Thanks
Old Apr 4, 2005 | 05:17 AM
SBV45's Avatar
SBV45
Leave it disconnected until you determine that the problem is gone away or not. After that, it is your call. You should make a trip to to service department anyway.
Old Apr 5, 2005 | 06:59 PM
RPharr's Avatar
RPharr
It is your wires being chaffed, they replaced mine and now it runs fine.
scbackpacker
2004 - 2008 F150
Mar 11, 2009 08:58 PM
nathan5603
1983 - 2012 Ranger & B-Series
Dec 1, 2006 07:25 PM
Red03XLT
2004 - 2008 F150
Sep 21, 2005 04:53 PM
nd8c
Jul 27, 2004 09:58 PM
OverHeight
Mar 5, 2004 03:26 PM
