Sponsored by: Kumho
shackle flip question???
Old Mar 31, 2005 | 02:49 PM
Goodold71's Avatar
Goodold71
I installed a shackle flip in my 71' F100 4X4. Now the rear dif moves to the side causing the passenger side rear tire to rub on the inside of the fender well. What can I do to eliminate this movement ? Can any help me here that has done a shackle flip and may have experienced this problem?
Old Mar 31, 2005 | 04:49 PM
ivanribic's Avatar
ivanribic
I've never heard of this problem before but I would check to see if your shackles are bent and check the shackle bushings also. My only other thought is if you drilled new holes in the frame for the bracket they may not be even on both sides, pushing the axle to the side.
Old Mar 31, 2005 | 07:13 PM
Goodold71's Avatar
Goodold71
No the shackles are not bent.And the bushings are new. And I placed the holes back where they were in the front. It just seems like the shackle is too weak to handle the side to side movement of the rear dif.
6t6merc
Sep 8, 2016 09:46 PM
96inline
Feb 18, 2016 09:42 AM
dillinewton
Offroad & 4x4
Jan 29, 2010 01:25 AM
tai-tanium
Sep 30, 2004 02:59 PM
rebocardo
Jul 8, 2004 11:05 PM
