3.0L Flex fuel
Old Mar 30, 2005 | 06:51 PM
motox214's Avatar
motox214
Red face 3.0L Flex fuel
Okay, has anyone even ran their 3.0l ranger on ethanol? Why would they make the option when you cant even buy ethanol? I live in utah and I dont know anywhere where it is sold. Also, do you have to use minimum octane gas when your ranger has the flex fuel option? Because whenever I put in premium (91), my check engine light turns on until I put in the lower grade gas (87)
Old Mar 30, 2005 | 07:46 PM
mcookd's Avatar
mcookd
I live in FL and I, too have never seen ethanol for sale. I would like to try it though, just for the heck of it. I have been running 93 octane in my 3.0 flex because it knocks when I use a lower octane. Not badly, I just can't stand the sound of my pistons swapping holes . But my check engine light never comes on.
Old Mar 30, 2005 | 08:52 PM
Ken00's Avatar
Ken00
I have heard you can buy it in the mid west.
You should have the codes pulled, the CEL indicates a problem.
Old Mar 30, 2005 | 11:12 PM
el conquistador's Avatar
el conquistador
Ethanol is common throughout the midwest since billions upon billions of bushels of corn are harvested each year
Here in iowa, ethanol is used in mainly 89 octane and sometimes 91 octane. the gas containing ethanol is the cheapest because there is no tax.
Old Apr 1, 2005 | 01:27 PM
motox214's Avatar
motox214
For anyone that has tried it, can you even notice a difference in power (more or less) or even MPG? What is the big difference between the flex fuel engine and the normal gasoline engine? Is there a major change so a car can run on ethanol? How much cheaper is ethanol? With the rising gas prices, I wonder if it would be a wise choice to order it by the 55 gallon drum? Is that possible, or would the extra costs of shipping make it a big waste of time? Sorry, but the whole flex fuel idea, just confuses me, especially when I cant even get ahold of it to try!!
Old Apr 1, 2005 | 02:01 PM
knoxnil's Avatar
knoxnil
Motox, I share your frustration. I live in the IL, also corn country, and the closest retailer that sells E-85 (that's what it is referred to) is 45 miles away, not worth the trip to buy gas. I know the farmers are just as frustrated because they are losing sales. I'll bet most people driving flex-fuel vehicle haven't got a clue what they have. I know there are alot of Taurus' out there that can handle E-85, wonder how many of their owner even realize it.
I've seen other discussions on this subject with links to web sites that list retail locations where you can buy E-85. Since this last wave of gas price increases, more questions about ethanol are being asked, and I'll bet we will see more availablility.
Old Apr 1, 2005 | 02:34 PM
yugami's Avatar
yugami
http://afdcmap.nrel.gov/locator/LocatePane.asp
Old Apr 2, 2005 | 02:15 AM
motox214's Avatar
motox214
This site showed that there is actually a gas station a few miles from my house that sells E85. I might be calling them and checking it out! I am excited. Thanks!
Old Apr 2, 2005 | 02:59 AM
Ponyracer's Avatar
Ponyracer
any time you use an alternative fuel in your FFV vehicle you need to change the oil to the FFV compatible. Check with your owners manual and read up on the FFV. I worked at a dealership for 11 years and am very familiar with the FFV vehicles.
If you check engine light is coming on using 91 octane then you have something that setting it and you need to find out what it is. 91 octane should not cause a check engine light to come on as a normal function. If you have pinging troubles, there has been talk here about some common fixes. One of them is to check the thermister sensor in the hose side of the airbox for dirt. If this thermister is dirty then you will not get a true reading for air flow, air temp etc and can cause pinging. I had this trouble with my 94 explorer and was unable to get any diagnosis help from my dealership, found this fix here and cleaned it and no ping since then. I used throttle body cleaner, sprayed it and carefully using a soft tooth brush, brushed the intake side of the sensor.
You did not say what year your Ranger was so these are just guesses as to what could be wrong.
Old Apr 2, 2005 | 12:21 PM
motox214's Avatar
motox214
Ponyracer- I have a 2000 3.0L 4x4 FFV. If I start running on Ethanol, do I have to resort to a different fuel filter, or is the oil the only thing I have to worry about? Also, If I change the oil to be FFV compatible, can It still be ran on normal 87 octan gasoline?
Old Apr 2, 2005 | 11:33 PM
Ponyracer's Avatar
Ponyracer
I think that the owners manual spells this all out. If not consult your local Ford dealership they should be able to get the information you need. I believe the filter is ok, because that was never mentioned only the special oil and it is expensive. You could also goto the Ford website and do a search for FFV vehicle information.
Old Apr 3, 2005 | 02:42 PM
Ken00's Avatar
Ken00
[QUOTE=Ponyracer]any time you use an alternative fuel in your FFV vehicle you need to change the oil to the FFV compatible. Check with your owners manual and read up on the FFV. I worked at a dealership for 11 years and am very familiar with the FFV vehicles.[QUOTE]
My 2000 3.0 owners manual doesn't state anything about a "special" oil for FF, I'm the original owner so it's the correct manual.
Old Apr 3, 2005 | 03:09 PM
motox214's Avatar
motox214
I also read the manual and couldnt find anyhing on Changing oil. I found that the Check engine light was coming from the air flow sensor! Nothing was wrong with the sensor, but my filter was quite dirty! guess its been a while since I cleaned it. But once I cleaned it, the check engine light turned off. I guess going through mud has its consequences.
Old Apr 3, 2005 | 06:13 PM
captain p4's Avatar
captain p4
I dont believe you have to change the fuel filter, because when i had my 3.0l flex i had to buy a special fuel filter for it when i changed it, that is different from the normal 3.0l filter from the factory.
Old Apr 3, 2005 | 09:47 PM
el conquistador
you would have to buy a special fuel filter for using E85, otherwise the fuel would eat through the filter. anything in which E85 comes into contact with is specially made. The fuel tanks, pumps, hoses, and nozzles at the gas station are usually lined with some kind of plastic otherwise the E85 would eat through them.
