I would like to find a 5 speed transmission to put on my 400. Is there one that will bolt up or what options do i have? Also, what would be a good rearend to use in a truck?
i might be able to get one of those off of the local salvage yard. Guy owes me for some mustang parts. I'll give him a call tomorrow. Thanks for the help.
All truck 400s use the 429-460 bolt pattern for the bellhousing. A ZF from an 80's 350 would be a good choice. You might have to move the crossmember and have the driveshaft modified or possibly play mix and match with the pressure plate / clutch disk though.
