Sponsored by: Auxito
Tach install
Old Mar 30, 2005 | 11:30 AM
Country4.2's Avatar
Country4.2
Tach install
I have a 2004 F-150 Heritage with the 4.2 Liter (distributorless). I have an aftermarket analog tach that I want to install. I was wondering where I need to hook into to receive the tach signal. Thanks for any info.
Old Mar 30, 2005 | 11:50 AM
FordPickupMan351w's Avatar
FordPickupMan351w
There should be a white/pink wire located at the PCM on the passenger side fenderwell. That is the stock tach signal wire.
Old Apr 1, 2005 | 05:59 PM
Country4.2's Avatar
Country4.2
I will check that out, what exactly is the PCM?? Thanks
Old Apr 1, 2005 | 08:58 PM
FordPickupMan351w
It is the powertrain control module, it is the engines computer.
Old Apr 5, 2005 | 08:34 AM
Country4.2's Avatar
Country4.2
Thanks for the info, I am going to get on that install maybe this weekend, I am really busy with school and stuff around the house, we are replacing drain pipe. So if I have any more questions I am sure you will hear from me.
Thanks again.
