dvd/navigation question
Old Mar 29, 2005 | 06:46 PM
Big Deezul's Avatar
Big Deezul
on my 03 eb I could listen to the radio or cd's while my kids watched dvd's in the back on headphones. I have read the owners manual 10x trying to figure out how to get my limited with navigation to do the same thing. Can somebody help me out.
Old Mar 30, 2005 | 10:23 AM
elbuencarlos's Avatar
elbuencarlos
Of course you can. Use the mode button in your rear seat control, you need to push this button until you see the leyend "Double play", with this option selected your kids can listen the DVD at the back while you listen a radio station or cd on the front. Push the mode button again to read "Single play" in the radio display to return to normal operation.
Old Mar 30, 2005 | 12:09 PM
Big Deezul's Avatar
Big Deezul
I can get it to say DVD shared but thats it?? Not sure what I am doing wrong.
Old Mar 30, 2005 | 12:41 PM
TDN's Avatar
TDN
You can enable or disable the Rear Seat Control (RSC) by pressing the headphone/speaker button on your Nav unit. When RSC is enabled, you will see the headphone/speaker icon on the Nav display. If you disable RSC, the icon should appear with a red slash through it.
When RSC is active, pressing presets 2 and 4 simultaneously on the Nav will enable Dual Play mode (or the RSC can enable Dual Play mode by pressing the headphone/speaker button on the RSC panel). The front speakers play the selected media and the rear speakers mute. In this mode, the rear passengers may adjust the volume and other levels using the rear seat control. Additionally in Dual Play mode, the front and rear seat passengers can listen to the same playing media. However, rear seat passengers listen to the media over their headphones (thereby being able to adjust the volume) and the front seat passengers listen via the front seat speakers. Press the headphone/speaker control again to disengage the rear seat controls (and Dual Play mode). The system returns to Single Play mode. Front and rear speakers will play the selected media.
When RSC is active, you can push the MODE button (on the RSC panel) to toggle between AM, FM1, FM2, CD changer, or DVD. If you're in Dual Play mode, SHARED illuminates in the radio display when the front and rear modes are set to the same media.
Press the MEMORY button (on the RSC panel) successively to allow rear seat passengers to scroll through the 6 memory presets in AM, FM1 or FM2. Press the MEMORY button in CD mode to advance to the next disc.
• In radio mode, press < SEEK (on the RSC panel) to find the next listenable station down the frequency band.
• In radio mode, press SEEK > to find the next listenable station up the frequency band.
• In CD mode, use the SEEK function to access the next or previous selection.
-Tom
Old Mar 30, 2005 | 05:10 PM
elbuencarlos
Thanks for your exact help TDN, I just put the instructions as they came to mi mind.
Old Mar 30, 2005 | 07:20 PM
Big Deezul's Avatar
Big Deezul
ahhh haaa I got it...thanks for the help guys
