How does one program a remote?
Old Mar 29, 2005 | 09:20 AM
katdaddy's Avatar
katdaddy
I have a 04 Explorer with and was given an extra remote. The one with 3 buttons that lock, unlock and sounds the alarm. How do I program it to work with my vehicle?
Thanks!
Old Mar 29, 2005 | 02:31 PM
marragtop's Avatar
marragtop
Give this a try:
Switch the ignition on/off/on/off 8 times in 10 secs ending in the on
position (I think). If you do this correctly all the door locks will cycle
on the last turn of the key. When the locks have cycled quickly press any
button on the 'new' key fob to register it with your truck's system. There's
a time limit on this, so do it quickly. The locks should cycle again and
that's it.
Old Mar 29, 2005 | 07:57 PM
JerrySimm's Avatar
JerrySimm
The procedure is in your owners manual. I did it on my '03, but it's been a while back. One thing I do remember, is that you must program ALL of the remotes when you do it. You're actually programming your Ex's computer to accept the remote's frequency / data signiture. I'm not sure it will work with the 3 button, but it probably will.
Old Mar 30, 2005 | 12:20 PM
katdaddy's Avatar
katdaddy
Thanks guys!! It worked like a charm! Appreciate the help.
Old Apr 1, 2005 | 12:36 PM
PE II's Avatar
PE II
Question
I tried the above on my '94 Sable. Doesn't work. Any help out there on a later model car. The OM says to take to the dealer ................ $$$
Thanks.
Mike
Old Apr 1, 2005 | 12:43 PM
marragtop's Avatar
marragtop
You may find what you need on this site. They also have an 800 number you can call. http://www.keylessride.com/
