hey, im new here and this is my first post. i am about to purchase a 1987 f150. it has a old, tired 300 I6 in there now. im going to lift the truck and put 36s on it. i want to either rebuild the 300 with performance parts to make it strong enough to pull me throguh the mud, or drop in a 351. what would yall do? also, how much power does the stock 300 have? and what are some site that sell performance parts for the 4.9?
If you want torque for mudding with big tires, your choices are pretty much the 300, or any V8 other than a windsor.
The 300 in the 87 is 200hp and 300ftlbs torque (its a late-60s steel crank F600 motor).
The 300 in the 79 is pretty much stock with a big cam and can burn the rear tires till the axle stops hopping and then chirp them in 2nd
my 300 pushes my 6 inch lift and 35's purty easy...well right now its broke down (dont let the discourage you) but when its running its running goooooood
Perhaps you should also mention what you mean by "old tired"? Is the compression bad? The 87 would be an EFI, so I suppose that it is not as amenable to many of the mods that earlier years can handle. But rebuilt heads for 300 cost about $300 off ebay, and then a clifford or offy intake with a 2 or 4 bbl carb will get you rocking. You have the EFI split exhaust already. You would have to rig a pressure regulator if you wanted to go back to carbed, but otherwise, should be do-able (automatic tranny?? -- might be issue too).
it doesnt have much power any more (high miles), theres something wrong with the timing, things like that, just old. so i was thinking if im gonna swap in a v8 now would be the time. i am on a pretty limited budget and if im not going to keep the 300 im going to put a 460 in it. but id rather keep the 300 if i can get it to make enough power. is around 375 ftlbs doable? oh, and cdherman, why would i want to switch it back to a carb? thanks for all yalls help.
The main reason for switching to a carb'd is the computer settings can't handle a lot of added hp. 375 ft lbs torque is quite doable but, not on a limited budget. First of all you would have to convert the mass air to speed density i beleive. After that you would need much bigger injectors and a custom flashed chip and even more than that im sure. For pushing 36s i think your best bet is to get a junkyard 460 and take it to a machine shop and do the works. you can get that torque with a close to stock engine using a 460 im sure. Anyways this is just my.02c and so you know im not being biased i have a 1988 efi straight 6 pushing 35s. Also if you do end up using the 6 thats great!!!! Get advice from colonel flashman or search for his post my built 300-6 i beleive. His engine made 400 ft lb torque 300 hp and pushed to 4600 rpms pretty easily all naturally aspirated. Although i beleive he said that build cost him like 3600 i think??? Anyways g/l with the 460 or the inline 6 which ever you pick.
Building up a 460 is costly, IMO. It's the biggest of the big blocks that Ford mass-produced, and people always think bigger is better. So they start with a 460, and get charged a premium for the parts.
I saw an article (have to see if I can find it) that goes into a lot of detail on how to build up a 400. Don't let anyone tell you they're not great motors, they are. They can be built up for massive performance gains over stock. They got a bad rap because Ford had to kill the performance to meet smog requirements in the early 70s.
But you can get a lot of power out of a 300, too. Just not as much as you can out of a 400. Those extra 100 cubes make a big difference. FWIW, the bore and stroke are the same on the 400 and the 300. The 400 just has two more cylinders.
Edit: Found it. It's actually in Bill Beyer's gallery:
The 460 will cost you about $texas if you just buy the parts.
Best and cheapest way is to get a donor truck. All the parts you need will be on it, except for the ones you break.
Off the top of my head the things you would need are:
motor
radiator
motor mounts
tranny
crossmember
transfer case ?
drive shaft ?
computer/wiring
exhaust
i love the 400s but i thought that a 460 would be easier to put into my truck, seeing as how its popular to do it. can you put a 400 in my truck cheaper than a 460?
