A/C Compressor Runs All The Time?
Old Mar 28, 2005 | 11:57 AM
Bad Company's Avatar
Bad Company
While checking my automatic transmission level this weekend I spent a lot of time near my idling engine. I noticed the Air Conditioner Compressor would kick on, and after a while cycle off. I jumped in the cab thinking I'd mistakenly switched the A/C on....its cold up here in the Northwest! Anyway, the heat was full on.
Any ideas folks? This isn't normal is it? Any thoughts or ideas would be appreciated.
Old Mar 28, 2005 | 12:36 PM
gseeders's Avatar
gseeders
yes, AC runs in all modes except the mode at ll o'clock position.
gseeders
Old Mar 28, 2005 | 01:11 PM
Bad Company
I have always been under the impression that the AC compressor would only engage its clutch when air conditioning was selected. Do all auto AC systems operate this way?
Old Mar 28, 2005 | 02:15 PM
gseeders's Avatar
gseeders
No, some only work in ac and defrost mode. my super duty was the first for me to have AC work in all modes except the one at 11 o'clock position.
gseeders
Old Mar 28, 2005 | 02:28 PM
slc10844's Avatar
slc10844
On my 03 the A/C compressor will cycle in all positions except vent and floor heat only.
Old Mar 28, 2005 | 02:32 PM
warrens250's Avatar
warrens250
You didn't describe your truck. In my 02 250 PSD the AC does NOT run with the air directed only to the dash or only to the floor. It runs with the switch in all other positiions. From reading the owners manual I believe this is normal.
For future reference, you should develop a Signature which describes your vehicle and also any personal info you want to share.
Warren
Old Mar 28, 2005 | 03:10 PM
Bad Company
My truck is a stock 95 F250 4X4 PSD.
Old Mar 28, 2005 | 03:44 PM
East mountain 99's Avatar
East mountain 99
Smile A/C always on
The AC compressor should be cycling while in the AC or either of the defrost positions. The AC removes the moisture from the air.
Old Mar 28, 2005 | 06:45 PM
wlihntr's Avatar
wlihntr
that is correct, the compressor will run in all modes except "vent only"(dash vents) or "floor only", it even states that in the manual
Old Mar 28, 2005 | 06:53 PM
Bad Company
I didn't even consult the owners manual on this one. I've been disappointed in the lack of detail it provides so I assumed it wouldn't answer this question. Thanks for all your information.
Old Mar 28, 2005 | 11:28 PM
Bluesbandit's Avatar
Bluesbandit
Every vehicle I've ever worked on only engages the A/C clutch when it's in A/C or defrost mode. Maybe some of the newer ones 2000+ engage in other positions but I can't figure out why they would. Most often, if your a/c is comming of and on (clutch quickly engaging then disengaging) it's do to a lack of refrigerant in the system. Or rarely a bad low pressure sensor. Put some guages on it and let us know what you find out.
Old Mar 28, 2005 | 11:36 PM
barebackjake's Avatar
barebackjake
it does it to keep the lubrication flowing through the system during the year also. its normal for it to cycle on and off. the only one it wont is in floor heat.
