Sponsored by: Real Truck
belt minder disable
Old Mar 28, 2005 | 07:55 AM
nhfire 77's Avatar
nhfire 77
belt minder disable
how do you disable the belt minder in a 2002-2003 E350 superduty? Is it the same procedure in all Ford vehicles with the belt minder? The dinging is killing me!! Sometimes its impractical to wear the belt, I know I should be wearing it and 90% of the time I do.
Old Mar 28, 2005 | 08:05 AM
CAT_man_963's Avatar
CAT_man_963
It should be in your owners manual - at least it is in my '02 F-250. It's a step process you have to follow - some silly thing like key on, headlights on, then off, then push the seatbelt release so many times, then..... Something like that. It was in my owners manual the step by step process.
Old Mar 28, 2005 | 12:03 PM
nhfire 77's Avatar
nhfire 77
Only if it was that easy, its a work truck!! no manual available!! thanks though
Old Mar 28, 2005 | 12:22 PM
CCtaker's Avatar
CCtaker
For my 05 the procedure is as follows
Put the truck in park, close all doors, turn the key to on(not running). The seat belt light will come on. Wait for it to go off(about 60 seconds). When it goes off buckle then unbuckle the seat belt 10 times(buckle, unbuckle counts as one). After you have done that 10 times the light will come back on for about 10 seconds, after it goes off again buckle then unbuckle one more time. The seat belt light should flash several times. If it does you are done. Hope this helps.
CC
Old Mar 28, 2005 | 02:01 PM
Antacus's Avatar
Antacus
Could not find it in my manual but that is pretty much how I disabled my seatbelt minder.
Old Mar 28, 2005 | 05:26 PM
tolie77's Avatar
tolie77
I have a 02 and all i do is push the seatbelt release button in and it stops dinging
Old Mar 28, 2005 | 06:37 PM
Antacus's Avatar
Antacus
Agreed, that works in older trucks. My bud's '02 350 is the same way, he just pushes the release and it stops chiming for about 2min. That does not work in my '05 250. Well, does not matter anymore since I disabled it, no chimes anymore but the light stays on a while.
Old Mar 28, 2005 | 07:03 PM
tolie77's Avatar
tolie77
On mine when i push the release button it does not chime any more
Old Mar 29, 2005 | 08:24 AM
CmprSpecial's Avatar
CmprSpecial
Try this link http://www.clubfte.com/users/monsta/...r_bodyFAQ5.htm It's near the top of our FAQ section....
Old Apr 11, 2005 | 02:20 AM
palindromelol's Avatar
palindromelol
Seat Belt Chime disable
There is a procedure in th FAQ's of this site.
It's like the hokey pokey
Old Apr 11, 2005 | 07:22 PM
rtoy's Avatar
rtoy
I have a 05 and the post from CCTAKER works great..............no more ding ding ding ding ding ding ding ding ding ding ding ding ding on the job sites........Thanks
P.S. Now how do you diable the key in ignition ding?????????????????
Old Apr 11, 2005 | 10:21 PM
palindromelol
Just disabled the key in the ignition ding TODAY!!!
1) get a 1/4" x 3/4" piece of electical tape
2) get a 3" skinny screwdriver or awl
3) turn on the ignition but don't start the truck
4) in the middle of the three holes on the underside of the steering column insrt the screwdriver or awl. Pull the key assembly out.
5) in the socket where the key assembly was, put a piece of tape on the little contact.
6) Reinsert the ket assembly.
1 minute flat.
hogryder007
Nov 27, 2014 09:32 AM
SBV45
2009 - 2014 F150
Aug 22, 2014 03:19 PM
shortride
2009 - 2014 F150
Aug 22, 2011 11:17 AM
kpolson2002
Jul 24, 2011 06:01 PM
R-T0r21on
6.4L Power Stroke Diesel
Jan 19, 2011 03:25 PM
