99 ford 7.3 wont start
Old Mar 27, 2005 | 07:35 PM
alilderanged33's Avatar
alilderanged33
drove fine and then turn it off and now it wont start. no instruments working, wait to start doesnt come or anything in the dash (no seatbelt light, check engine light, gas gquge doesnt move, etc). turns over but wont start. any help would be greatly appreciated.
Old Mar 27, 2005 | 08:42 PM
vancouverpower's Avatar
vancouverpower
I would start off with the simple things first, the fuses. Mt 99 wouldn't start a while back because of a blown fuse. Don't forget to check the fuses under the hood also.
Old Mar 27, 2005 | 09:03 PM
alilderanged33
checked fuses
we checked the all the fuses and all were good. i would turn over but no start. no guages or lights in the dash work. radio and lights still worked fine
Old Mar 27, 2005 | 09:13 PM
vancouverpower
I just tried to do a search to find some info for you but I can't seem to find anything to help. I do know that if the tach doesn't move at all when you crank it over- it is most likely the cps. But I don't think that would affect your gauges. I'm sure somebody will chime in.
Old Mar 27, 2005 | 09:17 PM
alilderanged33
nothing in the dash worked when it was turning over---completely dead cant figure it out
Old Mar 28, 2005 | 04:45 AM
slc10844's Avatar
slc10844
If the fuses are OK, start checking for a loose or corroded connector somewhere. Could be under the hood or under the dash.
Old Mar 28, 2005 | 07:30 AM
alilderanged33
went and talked to the ford mechanic--no clues having it towed to them this morning--will post the solution after it is fixed
Old Mar 28, 2005 | 01:41 PM
alilderanged33
stuck the key in it waiting on the tow truck and all the lights came on. started the truck and drove it to the ford dealer and they couldnt find anything wrong with it--figure that one out thanks for all the help though
